+ or - in centre of dc on t-amp - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th February 2006, 10:26 AM   #11
Pano is offline Pano  United States
Pano's Avatar
Originally posted by sreten
anything designed to run off a car battery will accept 14V dc.( Or it would be in big trouble.)
A logical assumption, but not totally accurate in this case. The T-Amp is NOT designed to run off a car battery, or to be used in a car. It is designed to be powered by 12V. Tripath state 13.2V as OPERATING CONDITION max, But 16V as absolute max. The problem is cooling.
Yes, it will run off 14V, but it is not really good for the chip as it lacks proper cooling in the Sonic amps. 14V won't kill it right away, but a number of DIYers have had chip failure at 14V. It can be done, but proper cooling needs to be implemented. The chip will work just fine at 12-13V, so why push it?
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Heaters and centre tap duderduderini Tubes / Valves 10 17th November 2010 10:38 AM
Suggestion on the best MTM centre wilsonj Multi-Way 14 19th June 2007 02:35 AM
centre speaker garymtb Multi-Way 24 7th June 2007 11:30 AM
Phantom centre channel with centre channel lol Toast_Master Multi-Way 5 5th December 2006 03:54 AM
2.5 Way for a centre speaker? Puggie Multi-Way 0 1st March 2005 04:09 PM
Copyright 1999-2017 diyAudio
