| Class D Switching Power Amplifiers and Power D/A conversion |
Location: Aberystwyth and Manchester, depending upon term times.
Hi All,
I hope I'm not asking a question that's allready been answered elsewhere on this forum, but can anyone recomend power transistors for use in Class D amplifier output stages? They would need to be rated to switch around 200v at 10A, with switching speeeds of at least 15kHz (for bass-only application) but ideally 100 to 200kHz. I'm looking for completmentary types - ie, a P-channel device and an N-channel device of similar characteristics. MOSFETS would seem the obvious choice, but having looked inside some not-so-old switching power supplies, NPN BJTs seem to be favoured - so possibly either would do for this application? So if anyone can recomend part numbers, books, articles on the web, data sheets or application notes I'd be very grateful. The amplifiers, by the way, are destinned for a small (about 1kW) PA system which will be tri-amped font-of-house and have full-range amps to drive monitors. I'm currently working on other aspects of the system, so I'm affraid that there won't be any progress reports regarding amplifiers very soon. Still, I'd appreciate any help... Thanks TOMi.
The Geek shall inherit the Earth. |
#2 |
If you want the amp to put out 1kW, then it's not a small amplifier! At these levels you'll not find suitable N and P channel power MOSFET parts, so the usual way is to use N-channel output devices, driven by something like an International Rectifier IR2110 chip, or by a discrete transistor driver. Have a look at the many 'home grown UCD' threads on here for plenty of information about this.
Don't even think of using bipolar transistors for the output stage, they'll need huge amounts of base drive current and you'll still have problems turning them on and off fast enough. |
#3 |
Thanks.
Sounds like what I expected. I'm not intending to 1kW out of a single amp though - more likely an absolute maximum of 500W per amp for a 1kW total outout for the system. You've confirmed what I suspected, that P channel FETS are not available in the same power classes as the N channel devices. I'll go back over some of the threads here, and look at the datasheet for the IC. Cheers!
#4 |
Go this thread for complimentary P-N chanel mosfet, I just put my design for 600W 4 Ohms chanel power amp. It's full range, so you can down the switching frequency, but output coil should be bigger! I use a pair of IRF640 and 9640...
Have a nice days! Fredos www.d-amp.com Yet another version of IR audio amp ?? |
#5 |
Ahh.. thanks again.
I'll look at this when I have more time (ie, when not at work!)
#6 |
Thanks Fredos,
That's very much the kind of circuit I had in mind - now at least I know it's a realistic proposition, and have some idea about what devices might be suitable. Cheers TOMi.
#7 |
| small-signal (small-power) fast switching complementary transistors | Lola Luna | Solid State | 3 | 8th April 2010 08:51 PM |
| Switching PSU for amplifiers | Gold_xyz | Solid State | 14 | 10th May 2007 03:23 PM |
| Switching regulators as amplifiers | tlf9999 | Class D | 9 | 24th October 2005 01:14 AM |
| The sound of two transistors switching | mikelm | Solid State | 34 | 12th February 2004 05:18 PM |
| Switching Power Supplys and Aleph Amplifiers | Mark A. Gulbrandsen | Pass Labs | 2 | 16th March 2002 05:20 PM |
| Page generated in 0.10464 seconds (77.41% PHP - 22.59% MySQL) with 10 queries |
