| Class D Switching Power Amplifiers and Power D/A conversion |
Hi
i am having problems simulating a class d amp in swCADIII. If anyone can spot the problem i would be grateful. The attached file has the extention .pdf but that needs to be changed to .asc for swCADIII to open it, as it is not possible to post that type of file. Thanks bob |
#2 |
Hello Bob,
I put some series-and parallelresistor to L1, a series-resistor to C5 and change Q1 from "NPN" to 2N 5089.... and it starts, please try it. Regards Heinz! |
#3 | |
Your simulation schematic has many problems - the driver pnp and output p-fet are upside down, Q1 neither has dc bias nor dc coupled drive from the comparator preceding it, and the input amplifier chain has questionable feedback (but you really need to fix the first two problems before beginning to worry about that). Regards -- analogspiceman |
#4 |
snip:
Your simulation schematic has many problems - the driver pnp and output p-fet are upside down, Q1 neither has dc bias nor dc coupled drive from the comparator preceding it, and the input amplifier chain has questionable feedback (but you really need to fix the first two problems before beginning to worry about that). , of course! But when the simulator strikes my first view is to the "simple" parts and after this small changes i see V(N001)....and closed it without a nearer view! Heinz! |
| Cathodyne Phase splitter simulation problem? | wildswan | Tubes / Valves | 6 | 29th June 2009 10:33 PM |
| About Tina and SwCad III simulators | gaetan8888 | Solid State | 0 | 28th January 2008 09:41 PM |
| problem with preamplifier simulation | Stefanoo | Solid State | 6 | 20th February 2007 10:51 PM |
| power supply pspice simulation problem | metebalci | Tubes / Valves | 9 | 10th August 2004 01:59 PM |
| Need help with simulation | Fuling | Solid State | 10 | 19th December 2003 07:44 PM |
| Page generated in 0.08275 seconds (67.20% PHP - 32.80% MySQL) with 11 queries |
