| Class D Switching Power Amplifiers and Power D/A conversion |
Hi Folks,
Just Drawn this schematic, Does the connections are OK with respect to the polarity and Negative feedback arrangement.... Comparator is UA760 differential comparator..... regards, K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#2 |
#3 |
#4 |
Account Disabled
Hi Kanwar,
That's TTL output so you might need a pullup no? Regards, Chris |
#5 |
Hello Kanwar,
for short view it seems OK for me, Chris please have a look to the schematic on page 2 : I think the output donīt need a pullup. Regards Heinz! |
#6 |
Its a TTL output, but its also Push-Pull type not an open collector type thats why it doesnot need pull up resistors... I think the polarity of audio signal at the output would be inverted and the amp behaves as an inverting amp So the connections regarding polarity are OK isn't it..... K a n w a r
#7 |
...and when not : there are minimal two easy possibilities to change the polarity!
![]() Heinz! |
#8 |
Hi HeinZ,
Yes two option one is to swap the output of comparator and second one is to swap the inputs....but the connections in my point of view were already OK...
#9 |
Hi everyone ,
If we put a signal at input 2 of UA760 than inverted signal is obtained at output 2, but non-inverted signal is obtained from output 1.. If we put a signal at input 1 of UA760 than inverted signal is obtained at output 1, but non-inverted signal is obtained from output 2.. Therefore its clearly evident that to get non inverted output signal one has to feed the signal to its either input, but take the signal from complemented output.... If input 1 is used than say output 2 will serve with same polarity of signal.... If input 2 is used than say output 1 will serve with same polarity of signal... Correct me If I were wrong.... K a n w a r
#10 |
Hello Kanwar,
still with this antique? Strange: no signs for polarities or a truth table, only (for luck) the schema! I would say itīs OK like You write! Regards Heinz! |
| Page generated in 0.09119 seconds (74.99% PHP - 25.01% MySQL) with 11 queries |
