Go Back   Home > Forums > Amplifiers > Class D
Old 9th February 2006, 03:39 AM   #1
Default T-Amp Channel Cutting Out
Hi All,
I just completed making a couple of mono'd T-Amps for what I hope is a fairly unique application (more on that later!). One channel works just fine, but the other one, after about 20 minutes or half an hour of operation, it stops playing with a none-too-loud crack or snap through its speaker (no noise from the amp from what I can tell). I let it set for a while, and plugged it in to my test speaker, and it played just fine! Further attempts to use end up with the same result.
Anyone have any idea what might be happening? Overheating? Bad connection? Combination of both? Shorting someplace? Does the 2024 have some sort of protection circuit that kicks in when something nasty happens? An upstream component?
If anyone has some ideas what it might be, or how I could go about inspecting these things, it would be appreciated. I only have a multimeter - no scope...
thanks,
Jeremy
Old 9th February 2006, 06:15 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Over heating will cause that amp to cut out. I've never really heard a "snap" though. Over current will also cause a shutdown, but you have to remove power to reset the chip. Are you running it near the limit? Do you have heatsinks?
Take the Speaker Voltage Test!
Old 9th February 2006, 07:33 AM   #3
Default Overheating
hmm, well I ran both boards in for a few months while I gathered ambition to do this, and I was using the same power supply then as I'm using now. But now I'm only using one channel, so I would expect the chip is even less stressed than it was... The supply is a 12V 3A regulated CB supply - I measured it as putting out just under 14V. I don't have the chip heatsinked, as the cases I'm using are very small, and there doesn't appear to be room.
The difference between the two channels cases, even though they appear identical is that the one that is cutting out appears to made from a higher density plastic. The non-working one's case is a little warm to the touch, and the working one is cold. I'll swap cases on them tomorrow (it's 2:30am out here in Halifax!) and see if this helps. :-)
thanks for the suggestion - I love your site BTW, panomaniac - the inspiration to try this came mainly from you. :-)
Jeremy
Old 9th February 2006, 07:52 AM   #4
Pano's Avatar
Default Re: Overheating
That's pretty hot for these chips. 12V is safer. At that voltage I would certainly heatsink it. Check eBay for the ramdac heat sinks from seller "wluk". New Egg has some copper sinks that should be even better.
Do you have the new amps without solder slug under the chip?
Sounds like the problem.
Hey thanks! Glad to be of help.
Old 9th February 2006, 11:03 PM   #5
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Do you know exactly what kind of plastic the two cases are made of? How are the binding posts mounted on the cases? Are they insulated from the case? If they aren't, try insulating them from the case or temporarily remove them from the case and see if the amp doesn't over heat then. Oddly enough, I ran into a similar problem some time ago with a certain plastic/rubber material that became more conductive as it was compressed. Using washers made of this material to insulate some binding posts from a metal chassis caused some issues that none of my EE professors could figure out... In the end the binding posts were semi shorting out to the grounded chassis through the washers. The case and the binding posts got warm too and amazingly the little SI board survived the whole ordeal (the sound did cut out and eventually stop and would come back after I let it cool down for a bit - sounds a lot like your situation).
That may not be the case with your chassis but who knows till you test it out.
Brian
Old 10th February 2006, 12:06 AM   #6
D0Hbert is offline D0Hbert  Philippines
I experienced the same thing, one of my speaker binding posts (right +) was touching the metal casing, thus shorting with the ground. Try this test, get a multi-tester, put it in 1x resistance, connect to your speaker output binding posts and see if you have a short between + and -, same with the input rcas.
Old 12th February 2006, 09:52 PM   #7
Thanks for the replies, guys.
So the first thing I tried was swapping cases - maybe the different plastic had an effect. That didn't seem to help.
Next, I picked up some copper RAM heatsinks at my local computer shop - the working channel sink barely heats up, but the channel that's cutting out gets too hot to touch.
Finally, I tried running the amp without the binding posts touching the case. While configured this way, I could no longer connect the amp to my main speaker (for reasons I'll get into in another post), and the amp was able to run for over an hour, but the heatsink was still cooking, though the speaker used was 8 ohm, whereas my main speaker is 4 ohm.
So I don't think this is a good result yet. I may as well describe everything I've done to the boards. (Just as a reminder, I'm using two boards in a mono configuration.)
1) I removed and bridged R01 to ground the left channel's input.
2) I tied together the red wires on the header so as to keep the amp always "on" when there was power.
3) I removed the mini-jack input so the board could fit in the case I'm using, and to make room for 4)
4) I put a 10 ohm, 1W resistor between the left channel's outputs.
5) I removed C3 so no signal would be going "backwards" through the input filter.
6) Between +ive input and -ive input, I put a 50Kohm resistor.
7) on the +ive input, I put a 27Kohm resistor, and then a 2.2uF cap - this went to the pad of R2.
8) The cap that's soldered across the speaker output in the original case was put much closer to the board because that's where it fit.
Any of that sound like an overtly bad idea?
To answer some questions - the boards are the newer ones without the solder slugs. When I unplug the amp from the speakers, and measure the resistance across the binding posts, I get about 12Kohms from both channels.
thanks,
Jeremy
Old 13th February 2006, 01:30 AM   #8
Pano's Avatar
Yikes!! Number one! You didn't move the cap in fornt of R01, did you?
Old 13th February 2006, 03:07 AM   #9
oh - nono - I didn't connect to the board at R01 - it's connected at R1, like it should be.
oops - after looking at the schematic I notice I got something wrong.
I wanted to mono-block the amps, and use the right channel. So I should have grounded out the input to the left channel, which is R02. I don't think this grounding out step is really necessary - it was just a precaution, and the other one seems to be running fine this way. As R01 is "behind" C3 (which I removed) bridging R01 should have no effect whatsoever.
Both mono amps were constructed in exactly the same way... I know the boards weren't manufactured at the same time (I originally bought two T-Amps, and fried one of them with a faulty power supply, so I had to order another from another vendor), but they both say Rev A01. If I remember correctly, they were made within a month of one another - I can't see the date codes when they're in their cases. Anyone have anything else I can check? :-(
thanks,
Jeremy
Old 13th February 2006, 08:56 AM   #10
Pano's Avatar
[i] As R01 is "behind" C3 (which I removed) bridging R01 should have no effect whatsoever.
[/B]
If you removed C3 then you may be shorting the 2.5V to ground. Did you check DC offset? If you have a resistance to ground, or a short, on the 2.5V side of the cap you'll get DC offset and that channel will use a lot of power.
On the unused channel you should just leave everything in place and tie to ground before or at R01. If you removed C3 and did any shunt to ground, that would not be good.
Maybe I didn't understand what you did. Can you post a sketch of your wiring diagram?
DAC cutting out malcontent Digital Source 10 2nd March 2007 10:19 AM
howdy - amplifer problem, channel cutting out Kolcun Solid State 1 28th November 2005 10:06 PM
Cutting Circles shanahan Multi-Way 11 17th June 2004 02:31 PM
Cutting MDF Vivek Everything Else 11 22nd February 2004 07:30 PM
Cutting Acrylic elizard Everything Else 22 11th February 2004 02:48 PM
Page generated in 0.16233 seconds (74.28% PHP - 25.72% MySQL) with 11 queries
