simple class D amp
simple class D amp
Old 8th February 2006, 06:48 PM   #1
latala is offline latala  United Kingdom
simple class D amp
Default simple class D amp
over the last 35 years i have built all kinds and classes of amplifier class a b ab but i have never tried a class d
do any you have a schematic hopefully with discrete components
that could be built any thing in the order of 20 watts or so
the few attempts i have made were very disapointing
regards trev
Old 8th February 2006, 08:01 PM   #2
bob123 is offline bob123  United Kingdom
Heres one i made earlier, it has been built and tested and works with some tweaking and the correct components. I suggest using a voltage comp for the switching sections.
This circuit gives a power output of
(15 / sqrt 2)/8 = 14W into 8ohms
:. 28W into 4 ohms.
Old 8th February 2006, 08:36 PM   #3
Gorilla is offline Gorilla  United Kingdom
Class D amplifers have two sub-catorgories; Carrier based and self oscillating. Carrier based usally use a triangle waveform to pulse width modulate the audio signal. Feedback can be added with degrees of success. Self-oscillating amps rely on some sort of positive feedback to achieve modulation. The UCD or SODFA amps are examples of this.
If you want something simple in concept try a PWM amp without feedback. Later if you wanted feedback could be added. More challenging would be a DIY UCD. The topology is almost unparalleled in terms of its component count simplicity but is more diffcult to understand.
Search the forum there are plenty of examples round.
Old 9th February 2006, 12:02 AM   #4
koolkid731 is offline koolkid731  United States
Default UcD
Nah, All it takes is to have total phase shift of 360 degrees and unity gain at oscillation frequency.
Koolkid
Old 9th February 2006, 01:37 AM   #5
classd4sure is offline classd4sure  Canada
Account Disabled
simple class D amp Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Right on KoolKid.
Here's a DIY UCD that should get you up and running with some minor tweaking.
http://www.diyaudio.com/forums/showt...threadid=55385
Chris
Old 9th February 2006, 04:26 PM   #6
TerryG is offline TerryG  United States
So would someone explain to me what I would hear differently if an amp had a 360 degree phase shift? I don't see how this would be a benefit or a downside. This keeps comming up and I don't get why.
TG
Old 9th February 2006, 04:36 PM   #7
surly a 360 degree phase shift would mean the output would be almost exactly the same as the input!
Old 9th February 2006, 07:17 PM   #8
Yes, except there will be a system loop gain imposed. If the gain is greater than unity oscillation will occur (Look up your favourite text book or Wikipedia on Nyquist stability criteria).
The difficult bit, like TerryG has alluded, is how this oscillation modulates meaningful sound .
Old 9th February 2006, 10:06 PM   #9
Account Disabled
The filter coil integrates the square waveforme of the power stage, creating an error signal which includes all circuit delays. This passes through a phase lead network, combined with the delays produces the required unity gain at oscillation frequency condition. The audio signal is your setpoint, you compare the two and there's your PWM audio signal.
Old 10th February 2006, 07:42 PM   #10
simple class D amp
Default simple clas d amp
thanks for the replies re the amp i have been sent a cicrcuit thanks bob
but as a bit of background when i posted the origional request i was thinking of something like the sinclair x20 or x10 has any one out there ever heard or got one of these as they were around in 1964/65 but then seamed ti disapear without trace any thougts or comments?
REGARDS TREV
simple class D ampHide this!Advertise here!
About a very very simple class D PA amp gaetan8888 Class D 8 13th March 2009 02:21 PM
SImple class D amp croccodillo Class D 0 29th May 2008 01:56 PM
Simple class B or AB amp. Mr Evil Solid State 3 21st August 2004 12:58 AM
