| Class D Switching Power Amplifiers and Power D/A conversion |
Hello
I've posted that question some days ago in the thread "sound of a psu" too. But cause there was no answer I will try it with a own thread now ;-). I'm just searching for a SPS for my T-amp (AMP3 from 41Hz.com). The reason is cause my self builded regulated PSU don't work proberly and I also read that SPSs should sound better with t-amps. I've found two SPSs now: http://www2.produktinfo.conrad.com/..._SPS_060_15.pdf http://www2.produktinfo.conrad.com/...ZTEIL_LPS64.pdf Voltage, ripple and load are the same. The main differences I can see are efficiency, adjustment range and switching frequency. Cause of the better efficiency, the higher adjustment range and the cheaper price (45 instead of 55 Euros) I would prefer the first one. But how important is the switching frequency. The first one I prefer has 50kHz but the second one from ASTEC has 110kHz?? Is that important and if yes which one would be better and why would it be better? many thanks Tom |
#2 | |
diyAudio Moderator Emeritus
Brian |
#3 |
Thanks for the answer!
What means SM supplies, maybe "switching mode"? And what frequency woul be better now, 50kHz or 110kHz? many thanks Tom |
| Page generated in 0.06802 seconds (81.16% PHP - 18.84% MySQL) with 9 queries |
