Go Back   Home > Forums > Amplifiers > Class D
Old 1st February 2006, 06:47 AM   #1
paulc is offline paulc  United States
Send a message via AIM to paulc
Default Looking for potentiometer
I've got a velodyne spl-800 amp with a bad volume pot. It's a 20k 1/2 watt, half inch diam. pcb mount pot. I've removed it and all that's written on the back is "20k" and "282F" i've searched through all the major electronics suppliers (mouser, digikey, electronix express, jameco) and I cant seem to find anything that is the same size and specs. I've got a pic of the pot on the board here, but I dont yet have a pic of it out of the board. If anyone can point me in the right direction I'd really appreciate it. also, before anyone asks, I know its a bad pot because a. it has no continuity, and b. when I jumper a pot in the amp works fine.
in any case, thanks for any help you guys can provide.
Old 1st February 2006, 07:22 AM   #2
JohnW is offline JohnW  Hong Kong
JohnW's Avatar
Alps or TW ALPHA
ALPHA
John
Life shouldn’t be take it too seriously, you will not come out alive anyway…
Old 1st February 2006, 04:13 PM   #3
thanks for the link, but I cant view any of their product pages. I can get as far as potentiometers, but after that all links are dead.
Old 1st February 2006, 04:29 PM   #4
JohnW's Avatar
Your right, try checking after CNY (around 5 Feb), you should also check the ALPS website - I'm sure they have similar parts,
John
Old 2nd February 2006, 06:10 AM   #5
MOER is offline MOER  United States
Default Pots
We have these in stock but they are dual 20K Linear taper.
We have then of thousands of parts in stock from part production runs
Old 2nd February 2006, 07:23 AM   #6
well alps has one that will work. sadly, they only sell in packages of 100, and their "request samples" link is dead (what is it with these electronics companies and dead links), so I'll give them a call tomorrow morning and see if they can do anything for me.
Old 3rd February 2006, 11:57 PM   #7
Default Pot replacement
In place of a 20K audio taper volume pot, you can put in a 47K linear with a 10K resistor between the wiper and the ground end to give it a taper.
Also, when replacing PCB mount pots, just worry about cramming something in the panel without worrying about the wiring. Then run wires to the holes in the PCB.
Dan Fraser
Which value of a potentiometer Alfetta87 Tubes / Valves 9 29th April 2008 12:56 PM
LED potentiometer ralf Pass Labs 20 19th October 2006 05:37 PM
Best Value of Potentiometer for T-Amp? HolyGhostFire20 Class D 0 3rd January 2006 10:39 PM
Potentiometer Value hongrn Parts 1 7th October 2005 07:41 PM
TKD Potentiometer Family Swap Meet 10 1st October 2005 08:40 PM
Page generated in 0.07342 seconds (83.19% PHP - 16.81% MySQL) with 10 queries
