Go Back   Home > Forums > Amplifiers > Class D
Old 31st January 2006, 07:11 PM   #1
mourip is offline mourip  United States
Default Fusing a Battery Supply?
Have any of you who have put one of the various T-Amp flavors into a new chassis, and used an SLA battery, added a fuse to the supply?
Thanks,
Paul
Old 1st February 2006, 10:28 AM   #2
Pano is offline Pano  United States
Pano's Avatar
Yes, I have. IAnd have never blown a 2 amp fuse, but you could use 3A if you thik 2 is too small.
A fuse is a good thing, just don't make it too big.
Take the Speaker Voltage Test!
Old 1st February 2006, 11:39 AM   #3
dnsey is offline dnsey  United Kingdom
I'd considera fuse essential - as near as possible to the battery. Thre's a lot of energy stored in even a small SLA at low internal resistance, quite enough to start a fire under fault conditions.
Old 1st February 2006, 12:02 PM   #4
Thanks for the replies. Since no one ever mentions it I had assumed that folks did not consider it necessary with a battery.
I already had one mishap with my modded T-Amp. I inserted the battery charger adaptor into the chassis female mount and it bent the hot pin to the chassis. The result was that I let a lot of smoke out of the amp and the little battery pumped its heart out in a brilliant display of excess. Luckily the internal wiring acted as a large low value resistor and bought me enough time to yank the adaptor out before a real fire started. The amp board was unharmed.
Fuses are good...
Old 1st February 2006, 12:19 PM   #5
gfinlayson's Avatar
Lead acid batteries can discharge a huge amount of energy in a very short time.
There are lots of accounts of accidents occurring with vehicle batteries and spanners. The average vehicle battery can deliver several hundred amps when shorted making it a very effective DC arc welder.
Old 2nd February 2006, 09:22 PM   #6
pburke is offline pburke  Germany
I recently taught my kids about how strong battery current can be by shorting out a small 7.2aH SLA battery with a piece of CAT5 wire - instant smokage and red-hot melting copper...
I use a 5amp fuse in my battery powered DDDAC, which draws about 1 amp - it has saved a few components quite frequently. Just last week I bought a new box of 5amp automotive fuses. I can't find them any smaller, but I'm putting this fuse only in there for the "bonehead mistake protection"
Peter
C- Battery Supply dsavitsk Tubes / Valves 4 14th May 2008 09:08 PM
Battery supply. harwoodspark Analog Line Level 10 23rd December 2007 05:28 PM
What happens if the battery supply is off balance ? Will Chip Amps 3 6th October 2006 04:39 PM
Battery Power Supply PH Analogue Source 4 3rd May 2005 12:03 PM
Battery Supply Help. RichardJones Solid State 4 11th June 2003 02:23 PM
Page generated in 0.09091 seconds (78.89% PHP - 21.11% MySQL) with 10 queries
