Go Back   Home > Forums > Amplifiers > Class D
Old 21st May 2007, 06:37 AM   #61
tyee is offline tyee  Canada
I have 3 amp modules and an SPS80 just waiting to be built when I have the time. Can't wait to hear it!!
Old 26th November 2007, 08:22 PM   #62
Bgt is offline Bgt  Netherlands
just did a test where I use a direct A/B switching on 2 stereo poweramps and found the mod of the 1 with the 4562 to give more 3D=depth than the 1 with the 5532. The latter is less stereo/wide than the 4562. The voice has more space with the 4562 chip. You need good speakers though to hear the sound widening with the 4562's.
Kind regards,
Bert
Old 28th October 2010, 09:05 PM   #63
I have just received 2 x Sonora 750 and 2 x Sonora 250. I will use the Ad 8620 because it is the only opamp I can tolerate. Why on earth is there 10 ohm in series with the supply lines and only 100 nf. after them. I have very bad experience with this kind of design. I think I will short circuit those resistors. By the way the modules is still delivered with Ne 5532 why ?
Old 29th October 2010, 05:51 AM   #64
ssanmor is offline ssanmor  Spain
The RC configuration in the supplies of each opamp are there for filtering purposes (further removal of switching frequency in the supply of the signal stage), although given the good regulation of the aux voltages, it can be for sure removed and experimented with.
Regarding the input opamp, NE5532 has good price/performance balance. Some customers specifically ask for other opamps, and we usually exchange them at no additional cost (in any case we won't charge 20 euro more for a 3$ opamp). Next time, please ask first.
Hope to hear your experiences soon!
Old 30th October 2011, 01:30 PM   #65
Default Discret opamp
Hi could it be possible to Change the opamp to a Discret single opamp ? I am not using the first stage . By the way my Coldamp is so good that a Tube entusiast think the concept ( including my very special mods ) must be something for the chinese market. None have ever seen anything like this. Every cap is plastic free and with silk isolation and oiled. Allmost all cables are silk isolated etc.
Old 1st November 2011, 09:10 AM   #66
Hello, Erlend.
The second part of the input opamp is integrated into the control loop of the amplifier, so we don't recommend tweaking with it. You can, however, substitute the default NE5532 opamp with another dual opamp (pin compatible) of your taste. Some people have reported remarkable improvements with LM4562.
Congratulations for your superb mods and performance. Could you post photos here?
Old 7th April 2012, 05:02 PM   #67
Default s450 or the like as current buffer
Hi ssanmor,
Would it be possible to use any of your amps as a current buffer (preferably no gain, or least possible gain) with a VAS design of own choice?
I am thinking of the possibility to build an amp with a VAS that I have the highest regards of, and then skipping its output current stage (that has no gain) for something else -maybe one of your sonora modules...
According to the data sheet the s450 seems to have connectivity for a potentiometer. Could this input for the power section be used as input for an external VAS?
- If so, what gain and circuitry follows this input?
Best,
Old 11th April 2012, 08:16 AM   #68
Sorry for the delayed reply.
The gain of our amplifiers after the Potentiometer header is 45V/V. This can be modified to some extent but we don't recommend so. You can attenuate at the input to have a lower effective gain, but that depends on the noise characteristics of your preamp as well.
Hope this helps.
New coldamp toy Pierre Class D 4 29th December 2009 02:31 PM
Real opinions on Coldamp iand Class D 96 1st March 2009 07:20 PM
Whistling Coldamp SimonInd Class D 8 1st August 2007 09:31 AM
Coldamp SPS80s PassiveO Swap Meet 4 28th January 2007 01:37 PM
Copyright ©1999-2013 diyAudio
