sonic impact t-amp in car? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th February 2006, 04:03 PM   #11
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Sorry, Ractis. It was an LD1085V12. I figured at least a 2A supply is needed, so a 3A regulator should do the trick.
The power of Science compels you!
Old 18th February 2006, 06:32 PM   #12
dnsey is offline dnsey  United Kingdom
I used a 330F 16V electrolyte capacitor and a ring inductor that looks like a small toroidial transformer. Would that be fine?
You need a cap of about ten times that value (at least), and - if I understand you correctly - a much larger inductor. The secondary of an LT transformer would do for experimenting with.
Think of it this way - the frequencies that you're trying to supress are in the audio band, on a low impedence line, so you need a filter of the same order as a speaker crossover.
Old 19th February 2006, 05:09 PM   #13
theAnonymous1's Avatar
I've have quite a bit of experience dealing with auto sound and I would have to guess its a ground loop issue.
If your using your cars head unit to supply the audio signal, which I assume you are, make sure the head unit and the t-amp are powered from the same wires. More importantly, make sure the t-amps -12v connection is properly connected. If not, the t-amp will pull the -12v through the RCA ground, very bad.
I've tried my t-amp in about 3 different cars without the use of a regulator and haven't had any over voltage or noise issues.
Old 25th February 2006, 04:44 PM   #14
ractis is offline ractis  Singapore
I finally solved the problem by buying a $15 electronic noise filter and putting it before the power supply into the t-amp.
Thanks all for your suggestions!
PS. dnsey, I think you're right. The noise filter I bought is probably a choke/capacitor filter and it certainly feels 20x heavier than the ineffective one I built
FS: Sonic Impact T-Amp oldman1 Swap Meet 2 6th December 2007 06:53 PM
Sonic Impact for MI amp mashaffer Class D 1 21st February 2007 08:25 PM
WTB - Sonic Impact T-Amp schmalex Swap Meet 4 20th January 2007 12:33 AM
Sonic Impact T-Amp Puffin Class D 11 20th March 2006 01:35 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
Copyright 1999-2017 diyAudio
