Go Back   Home > Forums > Amplifiers > Class D
Old 20th January 2006, 09:22 PM   #1
Eggzy is offline Eggzy  United Kingdom
Thumbs up Enclosures
Guys I've made some enclosures. I put them on ebay. here's the link to one of them:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MESE%3AIT&rd=1
maybe can make enough to pay for my 2020 [just built & ready for testing....but i'm scared!]
cheers
Old 22nd January 2006, 11:42 AM   #2
Trebla is offline Trebla  United Kingdom
but i'm scared!]
Why?
Old 22nd January 2006, 12:31 PM   #3
...Scared in case it didn’t work...but amazingly it worked first time.
Initial impressions? It started off a bit dull but came to life after 10 mins warm up, it's a very rich mature sounding amp, listening to strings is gorgeous...and that's with a crappy cd source! It’s a a T-amp with balls
This amp took a lot of prep because:
1. It came sans instructions
2. The English translation is pretty poor
3. The components were not coded, so I had to use a process of elimination.
Get one e80 &P&P
Old 22nd January 2006, 01:43 PM   #4
A slightly different experience to mine.
My amp arrived with instructions which i thought were quite good. Took me about three hours to build up the pcb, taking breaks to avoid eyestrain. Then it worked straight away.
I made the mistake of removing the pot in order to upgrade to an Alps blue. Things got messy and i should have just bypassed it. However this is a worthwhile upgrade.
Enjoy it.
I like your cases are they oak?
Old 22nd January 2006, 03:55 PM   #5
Default oak cases
Trebla,
re: The 2020 instructions. was it just a copy of their PDF file or did it have all the components marked out?
I got a head magnifier to do my assembly, I looked like an idiot but it's fantastic for detailed work like this!
yes the case bodies are solid oak recycled from kitchen units!
trebla, you say "I made the mistake of removing the pot in order to upgrade to an Alps blue"
is the alps blue physically bigger than the green alps stock pot?
the case for my 2020 will be like the others but with an ovoid fascia
Old 22nd January 2006, 04:18 PM   #6
The instruction sheet I got was the same as the set that is available on their website. I found it clear enough. The capacitors have the values printed on the top and everything else seemed self explanatory.
The Alps blue is much bigger and not designed for pcb mounting. Therefore my pcb is no longer fixed to the front panel but now bolted to the base of the enclosure.
Old 22nd January 2006, 06:45 PM   #7
Lostcause's Avatar
Eggzy, nice work, like the case.
The 2020 was a good buy then?
Good to see it fired up first time!
Go for the alps blue....I have them on my T's
Lee
Old 15th February 2006, 11:28 PM   #8
Default mor T-AMP enclosures
here's some more i've got on ebay
cheap as chips, a big one went for £1.49 last week!
need help with first sub enclosures NallaN Subwoofers 4 20th January 2008 06:08 PM
enclosures.. Keyoke Chip Amps 20 23rd November 2006 05:08 PM
new enclosures for 105.2 qguy Multi-Way 0 14th March 2005 07:18 AM
X-amp enclosures? FullThrottleRic Pass Labs 1 12th February 2003 04:41 PM
Page generated in 0.12699 seconds (74.53% PHP - 25.47% MySQL) with 11 queries
