AD Vs BD Modulation in Class-D
Old 25th May 2010, 01:28 PM   #31
AP2 is offline AP2  Italy
Banned
Hi all,
my free opinion on "BD modulation" is that noise= *2,(double transient creates effective +noise),also not is true a greater efficiency than the modulation AD.
PWM out (pwm + DT) the integral of the area is almost equal to the modulation
AD.
EMI not changed but IMD yes.
Old 25th May 2010, 01:57 PM   #32
81bas is offline 81bas  Germany
Originally Posted by Pafi View Post
I guess you mean: balanced (bridged) output has no common mode ripple. Yes.
Yes, I meant BTL configuration...
But 1 or 2 volts at 250...400 kHz is piece of cake. The switching transients are the real enemy!
Agree
The frequency of common mode output ripple is the switching frequency (unless you use BCA topology).
BTL configuration with BD modulation doubles the radiated frequency at non zero modulation indexes. Having Fsw=500kHz, we will get 1MHz. And this is something bigger, than piece of cake, I would say
And - as Kanwar mentioned - it can be filtered out easily.
Filtered means lowered by some factor. But it does not mean 'cancelled', reduced near to zero, as in AD modulation.
AD modulation in half bridge has the same common mode ripple, so I don't understand why would this be an issue.
I would say, AD or BD modulation is applicable for BTL configurations only, not for half bridges.
Old 25th May 2010, 02:00 PM   #33
Pafi is offline Pafi  Hungary
If there were twice as much transient with the same amplitude. But tipically there is not. You should compare AD @ fsw=500 kHz to BD @ 250 kHz, so there are the same number of transients. But at AD one transient has double amplitude!
Old 25th May 2010, 02:16 PM   #34
Radiation can come from different parts, but previously you said common mode output voltage, I think we would better to stay with this now. Common mode freq does not double. Please think it over! What doubles is the output ripple on the speaker, wich is in differential mode!
Yes, but who cares, when a much more agressive source of EMI still exists?
So you havn't heard about BCA? But it doesn't matter. My point was: if common mode ripple were a serious problem at BD modulation, then why it isn't at single ended AD? (Or you really think AD is only for bridge?)
Old 25th May 2010, 02:48 PM   #35
Workhorse is offline Workhorse
Workhorse's Avatar
Bingo...!!!
2 AD half bridges with clock in phase and audio signal out of phase results in BD modulated bridge[BCA does the same in half bridge while using 2 inductors and both switches switching at same time at idle.], there fore i don't think that the common mode component in BD is that much troublesome, when the same also exists in Half-Bridge AD.
Old 25th May 2010, 04:03 PM   #36
Sure I've heard about it. And if you once look at the K-series schematics, then you will find at least 2 notch filters tuned for different frequency in its output filter section: Fsw and 2*Fsw. And please do not say, that BCA doubles the radiated frequency, and usual BTL configuration with BD modulation doesn't! Each output wire in BTL configuration with BD modulation radiates its own ripple voltages, which are always in phase and in sum they are giving doubled frequency at non zero modulation index.
Ok, you may don't care about the output ripple voltage till you have more agressive source of EMI
Old 25th May 2010, 05:16 PM   #37
I've already asked you to not mix radiation in general and common mode ripple. Common mode ripple freq is Fsw in 3-level modulated bridge, but 2*Fsw in BCA. If you don't believe me, then do your homework: run a simulation, or use your mind to analize it!
You can't be serious! sin(x)+sin(x) wont be sin(2x)! Why would sin(x) be cancelled? In the difference there is no sin(x), that's why only the even components remain in the spectrum of the differential signal. (Even components are out of phase when there is modulation, otherwise zero.)
Old 25th May 2010, 05:44 PM   #38
ericbrooking is offline ericbrooking
I don't think it's good to talk about quantization here, since PWM is basically analog. We can say carrier freq. component, or switching freq., component...
Interesting, I guess it's a different point of view. Since my loop is comparing the switched output to the analog input to create the error, and we can do noise shaping, I just tend to think of BD as a quantizing choice regardless of sampled time or not. I do see your point of view as well though. I think it may be useful to look at it in different ways.
Your second point on distortion I agree with 100%.
Cheers
Old 25th May 2010, 06:09 PM   #39
Ok, I will do simulation and I will post result here
do you really think, that the residual is of a sinusoidal form? Please, take a look on the ripple at high modulation index. It is some quasi-sinusoidal periodical stuff, and when it is summed from both output wires (radiated in common mode) in BD modulation, then its period is halved (freq doubled)...
In AD modulation it does get cancelled in common mode, because this quasi-sinusoidal stuff is of the same form on both wires, but of opposite sign.
stuff(x) - stuff(x) = 0
Sure, in real world it is not fully cancelled, because of difference in output filter parameters between half-bridges, wire lengths, etc, but the main amount is usually effectively removed when using AD modulation.
Old 25th May 2010, 07:08 PM   #40
Banned
The conversation is interesting but perhaps I get lost in translation.
For me they are two separate issues. One is the noise (pink-noise at output), this is much greater than in the BD modulation. second point is the noise (EMI radiation). this depends on the shape of the square wave, the angle tips contain GHz and these are double in the case of BD. eg, an SMPS at 120V generate minor40% of EMI compared to an A 60V. therefore not a question of square wave amplitude only.
I agree with 81Bas, quantization error is double, in fact bd modulator has a lot more than IMD (3.5 kHz-7, 5KHz on IMD test).
AD Vs BD Modulation in Class-DHide this!Advertise here!
Flux modulation 454Casull Multi-Way 71 3rd November 2011 12:21 AM
How many modulation methods in Class D amplifier ? xuhaoz Class D 20 5th December 2006 05:15 AM
Alternative modulation schemes for class d amps Nirav Desai Class D 6 10th January 2005 10:26 AM
Class D Modulation Scheme pokka Class D 7 15th December 2004 08:33 PM
new class D modulation method? sfx Class D 12 6th October 2004 08:02 AM
Copyright ©1999-2017 diyAudio
