| Class D Switching Power Amplifiers and Power D/A conversion |
What happens when class D clipp's? What does it sound like? as compared to, say, a class A/B ?
#2 |
Depends on the topology used, the Hypex UcD modules sound very much like a standard class A/B amplifier. But really, why would that be a concern? Will you be running a class-D amplifier near its maximum rating? If so, you need a more powerful one perhaps
Best regards, Sander Sassen http://www.hardwareanalysis.com |
#3 |
This will mostly depend on the feedback topology used. Some additional soft-clipping measures can be taken as well.
If no soft-clipping tricks are used the following applies: The least nasty (i.e. cleanest) clipping is from non-NFB topologies closely followed by first order loops with a high dominant pole freqency. Higher order loops have the habit to "stick to the rails" when driven into clipping. Regards Charles |
#4 |
Greet's
I was running my amp into clipping for a prolonged time over the new year ( celebrations and all that ). The amp is a home built self osc classD of my own design. The first thing that goes is the bass, this is followed by audiable clipping across the rest of the spectrum that sounds quite soft in comparison to A/B clipping. I would say the amp sounds like it backs down during clipping. I would not describe it as a harsh or damaging clip sound. I was rather drunk but it can't have sounded that harsh as i let it carry on like that for a large part of the early morning celebrations, i wouldn't delibratly harm my baby LOL I can't speak for the other amps on here but i think the clipping is certaintly no worse than A/B. I gather you are worried about the amp self destructing at clip or somthing. I know i was, but after a few partys my confidence has grown and i now know it is rarther hard to damage these amps. The only time mine is destroyed nowadays is when i'm hot pluging and removing components from the breadboard. Regards Mad.P P.S The amp was running 80RMS into 8R when clipping. Lasted all night!
The perfect amplifier is a piece of wire with gain.... |
#5 | |
Nitrate,
#6 |
You can even run them into clipping at quite high-frequencies for prolonged periods. Now try this with the average AB amp out there !
Regards Charles |
#7 |
Hi Sander,
Please have a mercy on Mad.P's amp..donot direct him to short circuit his amp...donot rule his mind K a n w a r
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#8 | |
Dear Charles Leymann, Nothing happened only harshness in Treble was encountered.... K a n w a r
#9 |
Hi Kanwar
How is your amp BTW ? Anything fried so far ? Regards Charles |
#10 |
Nothing Fried in the amp...but it fried a 20MFD cap connected as a shunt to check out capacitive load drivabilty...that all....
One question...In my POST filter feedback amp when no load connected..i.e. open circuit ..does the feedback automatically take cares of Q of Filter.... when no load is connected...I have cliiped the amp with open circuit and nothing happened... amazed... K a n w a r
| Clipping | richie00boy | Class D | 2 | 16th January 2008 05:36 AM |
| class-d behavior at clipping | raintalk | Class D | 7 | 13th September 2007 12:34 PM |
| Clipping GC? | drfrink24 | Chip Amps | 29 | 1st April 2005 10:14 PM |
| What is clipping? | guitargully | Solid State | 5 | 25th February 2004 08:24 PM |
