Go Back   Home > Forums > Amplifiers > Class D
Old 27th December 2005, 08:15 AM   #1
bob123 is offline bob123  United Kingdom
Default Mosfet output stage help (please)
Hi all
I have just built a bread board class D amplifier, It works fine with bipolars on the output (npn and pnp), When i put mosfets on there it gives a wierd wave and starts misbehaving, I know this is due to the input capacitance of the mosfet. How can i simply get round this as i dont have a clue as to driving mosfets at high frequency.
The FET are
IRF530
IRF9530
The switching frequency is 200Hz and they are currently driving by the output of a comparitor, I have added a resisor and diode to give some dead time as they were getting hot.
Rob
Old 27th December 2005, 09:00 AM   #2
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Post your schematic..
It is very doubtful that your comparator will drive the mosfets directly.
You'll probably want to keep your previous NPN/PNP output stage as a low impedance buffer (high current driver), and use that to drive the gates, possibly each through a level shifting capacitor.
Good luck.
Chris
Old 3rd January 2006, 03:25 PM   #3
nitrate is offline nitrate  United Kingdom
nitrate's Avatar
Hi there,
200Hz ? I do hope you meant 200Khz LOL
Post the schematic so we can help...
Mad.P
P.S Hope your not planning on plugging this one into the mains
The perfect amplifier is a piece of wire with gain....
Old 3rd January 2006, 08:38 PM   #4
Well i dont have time to model it on LTspice but heres a simalar crocclips model, I have changed a few things such as
Due to the lm311 being a comparitor i have put a 1k resistor from the output of the LM311 comparitor to the +15v rail.
The component values on this are quite likly to be wrong but you get the idea, It is not the exact cicuit that i have built.
As for the output stage using transistor as is on the circuit the transistor output works but does not give a square wave, It has a dip in the middle of the wave. Does anyone know what that is?
When i put mosfets on it the whole thing gives a very odd wave shape.
What can i use to drive the mosfets as i assume i need lower output inpedance for the base of the mosfets to drive the capacitance.
I am using IRF530 and its complement.
Oh and yes i did mean 200KHz
Old 3rd January 2006, 09:18 PM   #5
The circuit:
Old 3rd January 2006, 11:48 PM   #6
kartino is offline kartino  Indonesia
kartino's Avatar
Hi Rob,
You need mosfet driver to switch the mosfet fastly.
Here is the simplest driver for P-N mosfet that may suitable to directly joint with your comparator.
Good luck!
kartino
Bipolar/MOSFET CFP output stage ashok Solid State 25 28th November 2010 09:31 AM
MOSFET or NPN for class A output stage AudioGeek Solid State 30 25th July 2008 07:34 PM
single mosfet output stage ? AudioGeek Solid State 1 1st January 2007 02:31 AM
Mosfet output stage question thylantyr Solid State 13 11th February 2006 02:45 PM
MOSFET output stage on Gainclone soundNERD Chip Amps 3 2nd November 2004 11:21 PM
Page generated in 0.08355 seconds (79.87% PHP - 20.13% MySQL) with 11 queries
