sla 12 volt battery for Chralize question
Old 12th December 2005, 09:25 PM   #1
scott_m is offline scott_m  United States
Default sla 12 volt battery for Chralize question
While I'm awaiting the delivery of the Charlize amp. module I've begun shopping for batteries.
First question - what size batteries are most people using for this amplifier?
Second question - a year or two ago I bought a chassis kit designed by Peter Daniel which is currently housing a 3875 chip amplifier. I like this chip amp, but I love the chassis and if the Charlize lives up to it's reputation, I'd like to take the chip amp out, and move the Charlize in. The problem I'm seeing is that the space in the chassis where the torroid is currently, that space is only 5" x 5" x 2 1/2" clear. I'm having trouble finding a 12 volt SLA battery to fit in that space. I'd like to have the amp and the battery in the same chassis, but maybe it's not possible to find a 12v to fit inside the case. If anyone has any experience w/ a small 12v (or really, a square 12v, instead of the 4 x 6 dimension I keep finding) I'd love to hear about it. Any ideas?
Also - any thoughts on replacing the alps pot with a carbon pot?
Thanks in advance.
Scott.
Old 13th December 2005, 05:54 PM   #2
tianguis is offline tianguis  United States
Scott:
What you need is a UB1213 1.3 Ah battery, which measures about 3 3/4" X 2" X 1 5/8". This is the battery used in the original RWA amp.
Of course, you'll have to charge it more frequently than the larger capacity ones. I've used this, as well as 3.5 Ah and 12 Ah batterries on the Charlize.
Larry Welsh
Old 13th December 2005, 07:24 PM   #3
harrycaul is offline harrycaul  United States
Tianguis or others,
Did you notice any differences/improvements when using the larger batteries (>AH) with the charlize?
Aaron
Old 13th December 2005, 07:46 PM   #4
Aaron:
I've done A/B/C tests and heard no difference with fully charged batteries.
Larry
Old 13th December 2005, 09:16 PM   #5
Thanks Larry! So I could in theory get 3 of the 12v 1.3 ah batteries and wire them up in parallel for 12v, 3.9 ah - for a more extended battery life.
Scott.
Old 14th December 2005, 12:52 AM   #6
Scott:
Not just theory! That would work just as you said. I've bought the 1.3 Ah batteries (new) on eBay for $1.99.
Larry
Old 15th December 2005, 04:16 AM   #7
Default SLA Battery, Charger, Charlize
Larry,
Another question about SLA batteries. I'm considering using the 12V-3.4AH SLA from battery mart: http://www.batterymart.com/battery.mv?p=SLA-12V3-4 or something similar.
The charger that they recommend is: http://www.batterymart.com/battery.mv?p=ACC-12BC0500D-1
In the description of the charger, it is stated that it can be safely hooked to the battery at all times providing a fully charged battery using a float charge. This sounds good to me. How would you wire the charger, battery, and charlize on/off switch. I'm assuming you clip the charger lines to the battery terminals. Where do the lines to the on/off/charlize connect so that you're pulling from the battery as opposed to the charger? Please spell it out for me as I'm really green when it comes to electronics.
Thanks.
Old 15th December 2005, 04:29 AM   #8
...meanwhile, I've ordered 3 of the 1.3 ah batteries which I'll wire in Parallel. The Charlize arrived yesterday. I may buy a wall-wart 12v to play with while I await the batteries, and to begin whatever break in process the caps require - but I'm mostly waiting for a free day or two around christmas to hook it all up. The Brian Bell 3875 boards and powersupply will come out - I bought some small metal cases from a catalog last month so I think I'll rehouse them without a selector switch and volume, and try running them off a foreplay pre-amplifier I have on the shelf. (Monica2 DAC is also in the mail. . .)
Thanks for the help!
Scott.
Old 15th December 2005, 10:18 AM   #9
vt4c is offline vt4c
Scott,
Just a note....
As I know that most wall-mart power supply doesn't come with a regulated supply and the output voltage will vary greatly with the load. Just to be on the safe side, please make sure that the power supply that you intend to get does not exceed above 14V.
sla 12 volt battery for Chralize questionHide this!Advertise here!
Purpose of 9-Volt Battery in Pearl? rgheck Pass Labs 1 13th January 2007 07:04 PM
12 volt battery voltage step up ThSpeakerDude88 Power Supplies 3 2nd October 2005 04:08 AM
9 volt battery becomes warm chazswanson Everything Else 1 2nd July 2005 08:26 AM
48 volt battery charger DPW666 Solid State 20 11th August 2003 05:01 AM
