Yet another version of IR audio amp ??
Old 8th December 2005, 05:45 PM   #1
zkaiser is offline zkaiser  Yugoslavia
zkaiser's Avatar
Question Yet another version of IR audio amp ??
Hi, to all people who are there, and willing to help me figure out some issues with this amp.
I've built pcb for 2 channel with schematic revised by pat allen and I added oc protection and those parts were altered:
MURS120 is in mine desing SBYV27-200 15ns/200V
irfbn23n15d -> irf640
ir2010 -> ir2110
all mm transistors are 2n
as IRF suggested heatsink is electrically conected to ground.
I did tested mine amp at +-25V and the main issue is that it drawns about 0.34A at +25V and 0.44A at -25V and inductors are cold, but mosfets are getting worm after 20sec not too much but . . . and frequency is 400kHz but if I try to set some lower then current drawning also drops a little bit. (0.2A and 0.3A)
So I would like to hear some oppinons about this and btw I am hopeing that is not issue in mine pcb layout . . . . .
Old 8th December 2005, 07:12 PM   #2
zkaiser's Avatar
More details
Old 8th December 2005, 07:12 PM   #3
zkaiser's Avatar
And of course opamp detail . . .
Old 8th December 2005, 08:43 PM   #4
lkadar is offline lkadar  Hungary
Hi!
Very nice board, very nice layout. Congratulations...
Old 8th December 2005, 10:32 PM   #5
zkaiser's Avatar
too bad that doesn't work right, for now!!!
Old 8th December 2005, 10:49 PM   #6
SSassen is offline SSassen  Netherlands
SSassen's Avatar
zkaiser,
Lets start at the beginning shall we? How about you post the schematic here so we can give that a good hard look to see whether there's some issues. I've worked with the IR driver ICs before and are intimately familiar with the IR reference design class-D amplifier.
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
Old 9th December 2005, 07:06 PM   #7
zkaiser's Avatar
Ok. Here is mine sch, so if anyone have something to say well I am hearing. . .
Old 10th December 2005, 11:04 AM   #8
koolkid731 is offline koolkid731  United States
IR2110 is likely too slow for switching amp application. It's a 500V HB driver therefore slower than IR2010 which is a 200V driver. Therefore get a IR2010 as in IR app note.
Koolkid
Old 11th December 2005, 11:06 AM   #9
zkaiser's Avatar
Therefore I don't thinking that this cousing any trouble for now.
If you look at input of IR you will see that there are some noise that shouldn't be here and I thik that this have something with power suppling . . . here is the pic. and time base is 1us/div
Old 11th December 2005, 11:08 AM   #10
zkaiser's Avatar
here are signals on gates, time base also 1us/div
Yet another version of IR audio amp ??Hide this!Advertise here!
My opinion on Audio Note M10 schematic - Japan version tim845 Tubes / Valves 1 25th April 2014 10:11 PM
Zen Version 4 R10 skidave Pass Labs 1 8th March 2007 07:52 PM
Zen Version 4 skidave Pass Labs 1 19th December 2006 07:36 AM
New version of Audio Tester has T/S Measurement..... venki Multi-Way 1 18th September 2005 04:09 PM
Copyright ©1999-2017 diyAudio
