Go Back   Home > Forums > Amplifiers > Class D
Old 2nd December 2005, 11:26 AM   #1
Default PCI card power amplifier
I want to introduce the idea of a PCI card power amplifier; possibly with onboard power supply. What are your thoughts on this? With the emergency of computer based audio I think it is time to start designing such a product.
Old 2nd December 2005, 01:53 PM   #2
ashok's Avatar
You might have a problem with power supply current.
On board power supply ? You mean batteries ?
There will not be enough space on most boards. Parts cannot stand up too tall. Off board plug in power is a possibility. What about all the existing switching noise in the area ?
How much power are you looking at ? 10 to 20 watts classD ?
Remember as power goes up, at a point heatsinking will be required.
AM
Old 2nd December 2005, 02:28 PM   #3
Yes, lots of problems need to be solved. Heat problem may be solved by heatpipes attached to computer case heatsink for silent cooling. See Zalman case. Power transformer can be located off board, in pc case. PCI card may be screened for noise. Would be nice to have a PCI card version of the UcD180...
Old 2nd December 2005, 04:12 PM   #4
The demand for PCI power amp would be tiny, probably limited to "emergency computer-based audio".
There's no real technical challenges. The market may not be there, or believed to be not there yet, therefore no product for it.
Any idea about potential market(s) for PCI audio?
Koolkid
Old 2nd December 2005, 08:45 PM   #5
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Default Why?
What would be the advantage of having a PCI amplifier? What data is going to be sent to it through the PCI bus? digital audio (SPDIF) information?
I really don't see how this would be an advantage at all over an external amplifier, besides not taking up the desk space.
The power of Science compels you!
Old 2nd December 2005, 09:41 PM   #6
anatech is offline anatech  Canada
anatech's Avatar
I've installed emergency computer speech systems. The amps have backup and the computer is the thing that is not reliable.
Maybe we should put the computer in the amp? But if it runs Windoze as well, it'll crash too!
We can't win.
-Chris
Old 2nd December 2005, 10:15 PM   #7
Pano is offline Pano  United States
Pano's Avatar
Somewhere, somehow, I've seen this before. PCI card with a Tripath chip.
No idea where I found it. Might have been in Korea.
Take the Speaker Voltage Test!
Old 3rd December 2005, 02:23 AM   #8
demogorgon's Avatar
Send a message via MSN to demogorgon
I'v had this idea before, and as for market, computer modification has quicly become a huge market. using 1-2 pci ports and making a 2*25W amp wich gets it signal internally from the pci would make a great product, and i belive it would indeed have somewhat of a market.
Old 3rd December 2005, 03:29 AM   #9
bogicp is offline bogicp  Yugoslavia
bogicp's Avatar
You are right, but noise isn't that big problem as you think... look at Lynx Studio professional pci cards and you will find that they have great specs, even measured in computer . They don't have screening at all.
Screening is good method but have some weakness...
In standard CD drive space you can have pretty big power supply, but where you place auxiliary power inlet... in front of PC?
Also, if you place near all main modules "off board", which purpose have name: "PCI card power amplifier"?
Best regards
boggy
Old 3rd December 2005, 03:38 AM   #10
karma is offline karma  Canada
karma's Avatar
ya i have a old isa with a lm chip on it. and the sound
Sound card with processing power Snickers-is Digital Source 3 30th May 2008 02:25 PM
FS: AMD 1 GHz CPU, motherboard, 256MB RAM, video card, power supply, network card Jimmy154 Swap Meet 0 14th June 2006 08:15 PM
soudn card to power amp MaXiZ Everything Else 3 4th February 2006 09:08 AM
Power Amplifier -> Computer Sound Card EchoWars Everything Else 4 20th December 2005 11:08 PM
Page generated in 0.10861 seconds (80.79% PHP - 19.21% MySQL) with 11 queries
