| Class D Switching Power Amplifiers and Power D/A conversion |
#131 |
Rebel Samurai!
Hmmm. I'm beginning to think about running an active sub to take a bit of stress off the t-amp (and speakers). If I put something together with something like the BASH sub amps from Parts Express can I get output for it from just after the volume pot on my modified Sonic Impact? Or will I need a buffer?
Thx! |
#132 | |
Combi Big shout for Pano
#133 |
I just got myself a t-amp and wanted to try some mod. The instruction here is quite clear though I have a couple of questions that I hope someone can help me with.
What does bridge a capacitor mean. Instruction said I need to brige C3 and C4 and I have no idea what that means. Also, how do I replace existing smd caps and replace them with bigger/better caps. I am used to "see through hole" or "point to point" soldering where I can see the 2 ends of the cap. With SMD - after I remove the existing caps, will I see the 2 ends as well. Lastly, which mods yeild most improve in sound. I am not good at these things so to start out I only want to mod as little as possible as I am affraid I may ruin the thing. Thanks in advance. |
#134 |
The term means to remove the SMD capacitor and to replace it with a piece of wire to "bridge the connection. This allows you to mount the missing device off the board in this instance. There is no need to try to mount a SMD capacitor in its place if a "bridge" is implemented.
A piece of wire like that on the end of a resistor is soldered in place of C3 and C4. Thus, allowing the cap to be wired off the board. The upgrading (replacement) of the input capacitors yielded the greatest enhancement to my ears.
Davet |
#135 |
Having done a few of these, I got best results with a small single strand of pre-tinned wire taken from a piece of approx. 18 gauge wire. Leave it an inch/3 cm long. Place one end right where one end of the capacitor is soldered to the board and hold it down with an alligator clip, tape or something. A hot soldering iron with a little solder on it applied to the spot will make the join very quickly. Then bend the tiny wire around the cap, trim the end, and repeat.
I found the greatest improvement with replacing the input cap, but I also got a noticeable and worthwhile improvement in bass by replacing the main power reservoir capacitor with a better grade and higher value, which is a pretty easy project. --Buckapound |
#136 | |
Just remember that what ever is tied to that line going to the sub amp - connectors, cables, sub amp input circuits and impedances, will all be tied directly to the signal you are going to amplify. That may not sound so good. But it won't hurt to try.
Take the Speaker Voltage Test! |
#137 |
Rebel Samurai!
"Buffer = Better. But it can work without."
thx, Pano. I was beginning to figure no one would have thoughts on this matter for me. Still in the planning stage for this project, I'll have to look for some buffer implementation info. "Just remember that what ever is tied to that line going to the sub amp - connectors, cables, sub amp input circuits and impedances, will all be tied directly to the signal you are going to amplify. That may not sound so good. But it won't hurt to try." Huh? Are you warning me that the post-crossover line-lvl output of the sub will bypass the input filter of the t-amp? Perhaps a better play would be to remove the Pot from the t-amp and set the T up as a amp, and set the pot as a passive / buffered pre so that I can keep the pre-out / main-in (sub) loop outside of the t-amp's circuitry... Still thinking... |
#138 |
Thank you Davet, I now understand. Now i feel like a dummy
#139 | |
What I'm saying is - imagine this: You take care to use the best stuff, wires, connectors, parts, amp. Then, right at the last, where the signal goes into the T-Amp, you solder in a bunch of extra stuff. Some long wires, some caps, random resistors. Do you think it would affect the sound? ![]() Not to mention that you will be driving the sub amp from a rather high impedance source, the volume pot. Not too good for the bass. Will it work? Sure! Will it work as well as you would like? Doubt it. As you stated, the best solution is to drive both the T-Amp and the sub amp from an active preamp. Buy one or make one, there's not much to it.
#140 |
I have a problem.. I thought i was a good idea to attach the new input cap's directly to the bridged space of the old cap's. Doing this I broke of the r80 resistor on the new revision board. Can i replace this? I guess, if this is possible, i have to replace 2 resistors but where is the other one and what value do they have?
Thanx |
| Help with Double Potentiometer Wiring | blindsjc | Solid State | 10 | 19th December 2007 08:44 PM |
| Sonic Impact's Potentiometer Question | HolyGhostFire20 | Class D | 0 | 30th December 2005 12:23 AM |
| Wiring choice : Siliver Sonic T-14 ? | bordins | Multi-Way | 2 | 25th November 2005 06:56 AM |
| Potentiometer replacement W100k? | redrabbit | Parts | 0 | 18th April 2005 11:06 AM |
| Page generated in 0.11489 seconds (85.69% PHP - 14.31% MySQL) with 11 queries |
