Go Back   Home > Forums > Amplifiers > Class D
Old 19th February 2007, 11:21 AM   #111
audio1st's Avatar
Default Re: Magnifiying glass
Originally posted by skibell
I pushed to hard and brought with me R80, which is in the new board R1, as I understand, now I should have no problem putting it back. But just by its side is a R1. Am I confused now???
You will need to replace R 80 ( previously R 1) otherwise you will only get sound from one channel..
New R 1 ( previously R 15 ) is the LED resistor..
Those boards can be a shock when you see them in the flesh after seeing the enlarged photos on your PC..
Old 22nd February 2007, 07:32 PM   #112
skibell is offline skibell  United States
Default Re: Re: Magnifiying glass
Got ya!
Makes sense, I appreciate your help.
Old 2nd March 2007, 09:27 PM   #113
ranger3 is offline ranger3  United States
Default 4 channels with 2 t-amps?
Has anyone combined the input wires of 2 t-amps to make a 4 channel t-amp in a single enclosure with 1 power supply?
Is their anything tricky about doing this or is it as simple as soddering both amps inputs to 1 set of RCA input jacks and doing the same for the 12v power?
Thanks,
Allen...
Allen...
Old 2nd March 2007, 09:40 PM   #114
This is no big deal to do. However, you may find with some sources, especially portable CD players, that the signal may be fairly weak, and you might not get the kind of volume the amps would be capable of with a stronger signal.
Driving from a preamp (or a battery-powered headphone amp) gives you plenty of signal for good performance.
--Buckapound
Old 5th March 2007, 03:35 PM   #115
OK, so I thought I had R 80 back on the board, but was not. Is there any other way to connect this R down the line, I mean a bigger R that I can solder? I bench tested the amp and I got sound (1 channel) with a CD and a 12V 2.5A PS.
Any help on how to re-connect R 80 somewhere down the line?
Maybe I should go back to tubes...
Old 6th March 2007, 02:34 PM   #116
audio1st's Avatar
Default Re: Re: Re: Magnifiying glass
You will need to connect a 20k resistor between one side of R4 and the C3 bridge..Please try not to lift R4 off the board..
Old 8th March 2007, 06:27 PM   #117
Sorry, I am a point-to-point kind of guys and just follow visual instructions from manuals. I appreaciate the help got here. Cheers.
Old 10th April 2007, 05:46 PM   #118
Default Replace my Replacment Potentiometer? Or...?
Folks, I recently reboxed my Sonic T-Amp per this helpful diagram:
http://www.diyaudio.com/forums/attac...amp=1097873773
During the initial check, double-check, and triple-check of my wiring effort I was so happy to have actual music coming out of both of the crappy little test speakers at my workbench that I did not notice what later turned out to be, when hooked to my usual pair, a massive channel imbalance (R>L). "Shucks" is a word vaguely related to the one that passed my lips.
If I crank the volume up to 85-95% of full, balance returns, but obviously with the Sonic T-Amp's distortion and my near-field listening set-up that's not the way to go.
Do I have a bad pot? I shudder to admit it, but my budget didn't allow for much and so it's an RS cheapo. Should I just re-solder? Replace with another/better? Or is it likely I have fouled up elsewhere...?
All patient replies deeply appreciated.
Old 10th April 2007, 08:17 PM   #119
Lostcause's Avatar
If you have a Multimeter then check both channels resistance at low levels. Put one probe on the input and the other on the output, measure, then do the same for the other channel... you will soon know if it is the pot or not.
I expect it is.
Old 10th April 2007, 10:28 PM   #120
Thanks, I'll give that a shot. Should have occured to me of course, but but but... 'preciate your time.
Help with Double Potentiometer Wiring blindsjc Solid State 10 19th December 2007 09:44 PM
Sonic Impact's Potentiometer Question HolyGhostFire20 Class D 0 30th December 2005 01:23 AM
Wiring choice : Siliver Sonic T-14 ? bordins Multi-Way 2 25th November 2005 07:56 AM
Potentiometer replacement W100k? redrabbit Parts 0 18th April 2005 12:06 PM
Page generated in 0.13687 seconds (82.09% PHP - 17.91% MySQL) with 11 queries
