| Class D Switching Power Amplifiers and Power D/A conversion |
Since the thrifty only had a 15 vdc wall wart available, can I use it or will it fry my T-amp?
#2 |
Don't do it! 15V will def fry the t-amp.
I faced the same issue myself. The amp is def fine at 13.8V as long as it's regulated. I read going from 12V to 13.8V increases power output slightly, but don't have the knowledge to say for sure. I use a big lab-style 13.8V 5A regulated psu, and it makes a huge difference to the body and weight of the sound. Dynamics improve too. Good luck :-) |
#3 |
I momentarily use a SMPS power supply - which came together with an USB-harddrive. 12V / 2A , very light and very good sound. I did not even have to modify it or change the plugs. You will very easy get one of those in computer stores.
/alohka/ |
#4 |
Thanks Gents! I'l steer clear of anything above 13.8 v. I had a co-worker provide a 12v tonight, but it is still lacking a bit o' juice.
#5 |
Here in the UK (and I imagine in most countries) the 13.8V regulated supplies intended for CB radio are plentiful and cheap - often free second-hand! They put out several amps, and seem ideal for the job.
I use one for my SI, and it works very well, just needed a bit of modification to silence the mechanical hum from the transformer. |
#6 |
Same here, they seem to be perfect....and quiet.
Although I did de-tune mine to 13.2V to play it safe! |
#7 |
Picked up a "lightly used" 13.5 vdc, 1.5 amp supply today for 39 cents US. I just love thrift stores!!
Here's a pic of my 39 cent mahogany tray for reboxing.
#8 |
How good would these be for the SI T-Amp?
Switchmode PS on eBat Australia If anyone is interested, I could buy then and forward them on to you.
Regards Fin |
| wall wart and basswood | BluesMagoos | Analogue Source | 6 | 9th September 2007 09:54 AM |
| Wall Wart for testing | bal704 | Chip Amps | 6 | 23rd October 2006 01:47 AM |
| best wall wart for t-amp, where? | gychang | Class D | 3 | 2nd October 2006 12:06 PM |
| 2 Wall Wart PS Question | Sherman | Chip Amps | 13 | 22nd February 2005 09:25 PM |
| Another Wall wart question | JCoffey | Chip Amps | 14 | 2nd December 2003 05:54 PM |
| Page generated in 0.08887 seconds (74.14% PHP - 25.86% MySQL) with 11 queries |
