0.0004% THD Class D Module - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th November 2005, 06:35 PM   #11
jeroen_d's Avatar
Why all this attention to THD? The numbers are nice though!
But what about IMD? Way more important in relation to perceived sound quality.
Old 8th November 2005, 06:53 PM   #12
IVX is offline IVX  Russian Federation
IVX's Avatar
I have even lower THD on the loudspeaker, then on the 4om resistor, at least in highs.
PS: Reducing THD by the huge loop gain, IMO, is not so much intelligent approach. I have said "STOP" to myself, when could not provide flat THD/Freq more, it's occured at 50db loop gain and no more then 500-550KHz idle switching, because i still prefer cold amp. But if i could develop the discrete amp with 30db loop gain and .005% THD at 10W etc, i would be really proud.
Best regards,
E1.
Old 9th November 2005, 04:15 PM   #13
Pabo is offline Pabo  Sweden
Lars Clausen
How do you measure THD and do you include noise? If the noise is not included it is not uncommon to reach those levels but if the noise is included I am impressed.
If something that measures good doesn´t sound good, measure again!
Old 9th November 2005, 04:18 PM   #14
IVX
What do you really mean by loop gain of 50dB? Do you mean the ratio between the modulating signal and the supply rails? If the loop you are using is hysteresis modulated I assume that you are using an integrator and this will naturally give a loop gain that falls by -1 or -2.
Old 12th November 2005, 08:06 PM   #15
IVX's Avatar
Yeah, integrator in use of course, i tend to call it PID even.
Best regards,
E1.
Old 12th November 2005, 09:13 PM   #16
IVX: Have you published your circuits somewhere? I am curious to see how you get your results, and how you calculate your loop gain.
www.newclassd.com
Old 13th November 2005, 03:15 PM   #17
IVX's Avatar
I have not such plans so far, though it's would be simple (TDA8939) and no bad amp to build by DIYers.
Best regards,
E1.
SMPS for class D module NewTesla Class D 40 16th May 2010 08:38 PM
Dlogixs class X module.. MatthewS Car Audio 1 6th April 2008 11:47 PM
ILP HCA40 - Class A module info JDeV Chip Amps 0 31st August 2005 01:48 PM
Cad Audio - another Class-D module raintalk Class D 0 9th November 2004 11:09 PM
Copyright ©1999-2017 diyAudio
