Class D amp using TL494
Old 12th December 2006, 05:07 AM   #101
stepheno is offline stepheno  South Africa
Default Half-Bridge Sigma-Delta UCD
Hello Ledmania,
Are you still around?
Just to let you know and make you glad: I have taken your half-bridge topology as suggested in your very first post (not really new to me and not new to the Japanese as you yourself witnessed - also not new to anyone designing power converters). I then took the IR reference design and combined the two into a Sigma-Delta UCD. The IR circuit is vastly simplified and improved.
Sincerely,
Stephen
Old 13th December 2006, 08:20 AM   #102
ledmania is offline ledmania  Philippines
ledmania's Avatar
Hi stepeno! Yes, I'm still around but not as frequent as I'm in Manila because I'm back again here on board the ship.
I'm glad that you resurected my long burried thread and I,m trying to imagine what sigma delta modulation you applied on it
Care for a schemo?
regards ledmania
Old 19th December 2006, 08:43 PM   #103
Tekko is offline Tekko
Banned
Post schems and pics, others may want to see.
Old 21st December 2006, 11:26 AM   #104
Hello Ledmania,
Interesting of you being on ships!
Tekko,
Unfortunately I am not providing a circuit.
I can but say that when compared to the IR design, it is so simplified that no level shifter and no negative voltages are required.
Sincerely,
Stephen.
Old 22nd June 2007, 08:18 PM   #105
eltonseemann is offline eltonseemann  Brazil
Thumbs up hi folks!!! Im new here
I implement ledmania concepts for tl494 based pwm but I use the IR mosfet driver IR21844 that simplifies a lot the work. No overcurrent nor external deadtime has aditioned (the IR driver introduct programed deadtime).
I found problems when more volume is used. The sound is distorced at peaks. Any sogestion for correct this?? What possibles causes? Any associated to mosfet driver at longer duty cycles?
I work at aprox. 120Khz (tried lower too)
+-56V source, commom mode voltage at error amp of tl494 = 3,6V (the app report from texas pag.8 afirm that work which commom-mode voltage range from -03V to 2V less than Vi)
Old 23rd June 2007, 05:47 AM   #106
layout
Old 23rd June 2007, 11:28 AM   #107
layout
Old 14th February 2011, 04:32 PM   #108
altium is offline altium  Bulgaria
Hi Ledmania,
I cannot open your schematic from this chapter: http://www.diyaudio.com/forums/class...tml#post764418
Can you upload him correctly, please?
Old 15th February 2011, 12:23 AM   #109
Pafi is offline Pafi  Hungary
I don't know what is the reason for your distortion, but this schematic looks horrible (no junction points, hardly readable characters), and basically the feedback is designed not at all. OPA without feedback: bad idea. IR21844 has too much dead time. (400 ns is too much.)
Old 12th November 2014, 10:26 AM   #110
luizcpimenta is offline luizcpimenta  Brazil
layout
Bom dia.
Conseguiu fazer funcionar esse amplificador?
Abrašo
Class D amp using TL494Hide this!Advertise here!
Doing a class D Amp project using TL494 circuitcity Class D 375 12th August 2016 12:13 PM
