Go Back   Home > Forums > Amplifiers > Class D
Old 2nd November 2005, 02:47 PM   #1
Default Small case for small boards
Hi all! Was just surfing around looking fpr a decent looking, not too expensive, case for my AMP3 and its SMPS and found this on ebay:
It is not very big and looks rather neat, if you can remove the painted giberish from the metal top. The price seems acceptable too. just be warned that I tried to contact the seller more than one week ago about combining shipping and still no reply...
Here's the link for one of these things, otherwise just search for "cd-rom case"
http://cgi.ebay.co.uk/USB-2-0-5-25-A...QQcmdZViewItem
Hope this was helpful for anyone...
Paulo P.
Old 2nd November 2005, 03:23 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Hammond Manufacturing makes some nice enclosures as well. I like their diecast aluminum enclosures. They work great as small enclosures for power supplies or amps because they're very strong, easy to machine, and can also act as a nice heatsink for any electronic parts. I also like the look of their new EMI/RFI plastic enclosures. Those would make a real nice case for a small amp.
http://www.hammondmfg.com/scpg.htm
Old 2nd November 2005, 03:31 PM   #3
UrSv is offline UrSv  Sweden
UrSv's Avatar
These from MAPOWER are not bad either and the sides should be usable as heatsinks.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 2nd November 2005, 05:30 PM   #4
indoubt is offline indoubt  Netherlands
indoubt's Avatar
For an Amp3?
You must be able to do something smaller than that.
There are also nice small enclosures available from electronic suppliers for approx 15€ that will fit both amp and a modes PSU. ( in Erope, Conrad is one of them)
My Amp3 enclosure is 14 cm of 35mm copper watertube. It includes all connections, filtercapacitance, Volume pot etc. Only part of the PSU is outside.
better be indoubt untill you're sure
Old 2nd November 2005, 05:42 PM   #5
amolan is offline amolan  Brazil
Hi All,
Nice case UrSv, where can I find one for me ?
Alexandre.
Old 2nd November 2005, 10:51 PM   #6
Neat idea, I like it !
Let the music flow
Daniel
Old 3rd November 2005, 11:04 AM   #7
Yes, OK, it is kinda big but I was thinking in my own needs... It has to accomodate a stepped attenuator wich needs more than 4 cm of width, one (or possibly 2) AMP3 board and the SMPS. Plus, space on the back for connectors, mains sockect, etc. I do like the MAPOWER one very much, and I jsut saw that it also comes in 5.25" sizes.
Where can you get it, PLEASE?
Old 3rd November 2005, 12:00 PM   #8
@pcspinheiro,
I've seen casings similar to this one called "Icy Box", but those were for 3.5" HDD, same design though.
Only top & bottom are alu plates, the side beams are something plastic, and the side walls are grated metal - you can see inside the box, but i'm not sure it's so good for EMI shielding and such.
The 3.5" are too small for toroids or anything of course - but small class-d amps could fit in there nicely - Even UcD180 with some kind of spms could fit as a monoblock, but the alu plate would only be 10cm*25cm*1mm, extra cooling fins would be needed I think.
Here's an in-depth review, which means nothing to us, but there's a lot of photo's of the inside!
Icy Box 3.5" Review
Old 3rd November 2005, 12:24 PM   #9
nitrate is offline nitrate  United Kingdom
nitrate's Avatar
How about a Large case for a large board/boards?
Mad.P
The perfect amplifier is a piece of wire with gain....
Old 3rd November 2005, 02:44 PM   #10
Thanks Ives Smolders, but that one is just too small to accomodate the AMP3 board with the toroids and the stepped attenuator, which is fairly large... The MAPOWER ones are kinda expensive too (more than 30€ + shiping from germany...).
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small Lian-Li PC case Spasticteapot Swap Meet 3 23rd December 2008 11:37 PM
How small can I make a case for a LM3875 kit? m0b1liz3 Chip Amps 9 3rd July 2008 11:10 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
Problems Preventing hum in a small case indoubt Chip Amps 13 4th March 2006 07:10 PM
Page generated in 0.12331 seconds (76.14% PHP - 23.86% MySQL) with 11 queries
