The cheap simple ClassD
Old 24th October 2005, 10:24 AM   #11
Pierre is offline Pierre  France
Banned
I am not sure at all about the level-shifter implemented inside the LM311...
Please have a look at another thread that is very active lately : "how to fix this sch". I proposed a simple topology for level-shift, gate drive and bootstrap. It hasn't been tested but should work better or worse. It is in fact the individual stages are very similar to your proposal, but it is simpler, and it uses a level-shifter based on a transistor after the PWM modulator.
Have you implemented that sch in real life?
Best regards,
Pierre
Old 24th October 2005, 10:54 AM   #12
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
I'm not going for an discrete solution but a cheap and easy one. The inverters are dirt-cheap and do a nice job at "cleaning" the signals.
The schematic hav'nt been implemented yet, but one of these days it will be.
The levelshifter from the LM311 will be fixed soon.
I'll have a look at some of the other threads (again) and return with the updates to the schematic
TroelsM
Old 24th October 2005, 11:07 AM   #13
classd4sure is offline classd4sure  Canada
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Default Re: Simm of the amp
Originally posted by TroelsM
Here's the first set of sim-result's:
The amp dos'nt osc at startup but it starts after a period when the signal goes negative. I don't think this is a problem.
At high pos. voltage at the output the freq drops very much. Hav'nt figured out why. It's very late 4.08 in the morning). Im not gonna work on that now.
TroelsM
You're right, it isn't a problem..... in simulation
I think you'll find it will be in reality. All it takes is a simple circuit to precharge it, and a slightly more complex one to provide a delay at turn on to ensure it has the time to fully charge.
Some level of frequency modulation is natural in most self oscillating amps but it shouldnt' drop too much. That's why it's good to switch at 500kHz instead of 320kHz. Then you dont' really care all that much if it drops down even 150kHz.
There may be ways of limiting it with tweaking feedback as well. I couldn't tell you how though. Maybe Charles can.
Chris
Old 24th October 2005, 11:20 AM   #14
tlf9999 is offline tlf9999  United States
Account Disabled
here it is.
Available on page 5.
http://www.cqpub.co.jp/hanbai//PDF/30391/30391_1syo.pdf
Old 24th October 2005, 11:27 AM   #15
Account Disabled
Sorry, what's on page 5 exactly?
Old 24th October 2005, 11:30 AM   #16
TroelsM's Avatar
Pierre: If this is the sch youre referring to (http://www.diyaudio.com/forums/attac...amp=1129882065). Then I don't get it... have you simulated it? The level at the base, at top BD139/BD140's wont ever be higher than approx 5V and it should be min 56v+12v = 68V.
Next point: At the moment of switching the BD's have a very low current gain and the base-curent will be pretty high. In your sch the basedrive wont ever be very high becurse of the 1k resistors.
Thats why I use the 40106-inverters. They give a clean switch and a high "current-gain" ast high Freq.
Please do coment.
TroelsM
Old 24th October 2005, 11:46 AM   #17
Banned
You are right! There is a mistake in that sch. Top of R2 should go to the bootstrap voltage, not to +12V.
No, I haven't simulated it, and I am afraid I don't have much time to do it now, if someone is willing to do it for me...
Old 24th October 2005, 11:48 AM   #18
TroelsM's Avatar
If I get the time i might simulate it later, but I still think that the current to the bases is way too low to get at fast switch.
TroelsM
Old 24th October 2005, 11:48 AM   #19
Banned
You may be right about base currents also. I only posted the sch as a proposal. Adding a couple of TC427 driver ICs instead of the BD's should work much better, anyway.
Old 24th October 2005, 12:01 PM   #20
nitrate is offline nitrate  United Kingdom
nitrate's Avatar
Hello all,
Interesting thread, can't wait to see how it developes. What frequency are you planning on running this amp at? I can't see the totem pole driver arrangement going too fast, also why the multiple dead time? One on the fet gate, one in the logic?
You all seem to be using the same schematic/sim software. Which is it?
Keep up the good work!
Mad.P
The perfect amplifier is a piece of wire with gain....
The cheap simple ClassDHide this!Advertise here!
Simple/cheap DAC? Znyper Digital Source 9 15th January 2008 08:52 AM
Simple and cheap sparkle Solid State 33 14th May 2004 05:19 PM
simple, cheap, 6L6 amp? help trespasser_guy Tubes / Valves 54 22nd March 2003 02:03 AM
Copyright ©1999-2017 diyAudio
