Go Back   Home > Forums > Amplifiers > Class D
Old 20th October 2005, 01:39 PM   #1
vern is offline vern  Israel
Question tripath 2020 with low efficiency speakers
Hello everyone, new here
I wanted to ask the forum if anyone has experience with driving low efficiency speakers with one of the tripath 2020 based amps (amp3, autocostruire, charlize).
Specifically, I'm considering the Charlize, but I'm not sure it will be able to drive my B&W CDM-1NT's (8ohm, 88db).
Thanks for any advice...
[http://www.bwspeakers.com/downloadFi..._info_CDM1.pdf]
Old 20th October 2005, 01:54 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
My IPL A2's are rated at 89 db and the Charlize has no problems driving them! Ideally, it would be best to borrow a class-T amp if you know anybody who has one. Even the Sonic Impact T-AMP would be a good guide!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 20th October 2005, 02:44 PM   #3
Default Re: tripath 2020 with low efficiency speakers
I use Carlize to power some big 3 ways (85 db, 4 ohm) with no problems. It will depend on your listening habits and the size of your room. If your room is not too big and you play music a low to medium level, then you should be OK.
Your B&W will love Charlize ! You will get a more present bass from this little puppy and keep the good mid and HF.
I plan to visit a friend and try my Charlize with some very good B&W 3 ways he have. I don't know if this will happen into the near future.
You should order Charlize and try it in a cheap prototype. This way, you won't have to pay big $$ to see if you like what you get.
Daniel
Old 20th October 2005, 03:06 PM   #4
I see the IPL A2 are 89db and 8ohm, only slightly more efficient than mine - so there's hope
As for trying a t-amp - it's based on the 2024 (15w) and weaker than the 2020 (20w) based amps. In terms of power should I just think of it as providing 75% of what the 2020 can do?
Old 20th October 2005, 03:17 PM   #5
Vern, there is no realistic difference between 15W and 20W so don't let it influence your decision.
Andrew
None of us are leaving this world alive. Enjoy it responsibly as you may.
Old 20th October 2005, 04:12 PM   #6
Nuuk's Avatar
I only mentioned the T-AMP as it is more likely that you may know somebody with one! I agree wit hthe others though - you should be fairly safe in buying the Charlize.
Old 20th October 2005, 04:44 PM   #7
Be warned, the CDM1NT's (i'm not sure if you have the old ones or those with nautilus tweeters) are a strange load.
They are not really difficult, but they do drop to about 5 ohms in the bass region.
The larger 7 and 9NT's had 3.3 ohm official minimal load on the specs. (The 9NT shared the N804's drivers)
Old 20th October 2005, 09:41 PM   #8
Positive opinions so far and I'm becoming more and more convinced I should go for it
Yves - About your warning:
CDM-1NT is the one with the nautilus tweeters. What do you mean when you say it is a strange load? What should I be hearing (or not hearing, as the case may be)?
Old 20th October 2005, 10:49 PM   #9
I meant the impedance vs frequency curve isn't easy for an amp to drive. You can't really hear it if the amp's got trouble, maybe it's going to clip faster and won't handle the bass so well.
The CMD-9NT and the N804 are worse because they are 3 way (impedance between 3 and 8 ohms)
You can't really hear it, but with less capable amps, the CDM-9NT and 804's were told to have anemic bass and harsh treble.
Don't worry, it's not that bad with the small CDM-1(NT) and the 805, less difficult do drive.
Go for it!
Old 21st October 2005, 08:51 AM   #10
Now that we are on this topic, do you guys think that I can get away with using a 41Hz AMP3 and a pair of wharfedale diamond 9.1 (86dB, 6 Ohm)? They won the what-hifi award for under 250£ stereo speaker (and I wanted them before anyway, because I always heard good reviews and also because of the price of 176€).
Cheers!
Tripath 2020 amp: 41Hz amp6 kits (unassembled) hifidaddy Swap Meet 2 10th March 2007 08:15 AM
Autocostruire Tripath 2020 Amp mourip Swap Meet 2 1st July 2006 08:57 PM
FR125S + Tripath 2020 Charlize, am I crazy? eVITAERC Full Range 4 6th October 2005 03:37 PM
ZEN brothers and low efficiency speakers jh6you Pass Labs 6 24th June 2003 04:35 AM
Efficiency of Two Speakers in Series markkanof Multi-Way 17 2nd May 2002 07:37 AM
Page generated in 0.12560 seconds (85.22% PHP - 14.78% MySQL) with 10 queries
