| Class D Switching Power Amplifiers and Power D/A conversion |
#41 |
I've tried TA2020 amps with two different speakers:
88dB at 8 Ohms, giving around 7 clean watts This was good, but sometimes I was frustrated when I wanted to rock out. Enough power for 80-90% of the time. 88dB at 4 Ohms, giving around 14 clean watts Perfect. Beautiful at low/mid volumes, and sufficiently loud to drive a moderately crazy new year's eve party. |
#42 | |
::: Squeezebox Touch Toolbox 3.0 and more ::: by soundcheck |
#43 | |
If you don't want a the input cap just use a high quality input trafo instead. It has several advantages over an input cap, and none of the drawbacks of direct connecting it. |
#44 |
Saturnus,
What are the advantages of the Trafo vs. Input Caps that you speak of? |
#45 |
kristleifur,
Did you really see a huge difference between running 4 Ohm speakers vs. 8 Ohm with Tripath 2020? Anyone else have opinions on this? Is the difference MORE pronounced with less efficient speakers (e.g. 88db)? |
#46 | |
2) You can get step-up input trafos so you can make more advanced input filters and/or passive line level filters without the use of a pre-amp. Or in any case eliminate the need for a pre-amp. |
#47 |
Saturnus,
BTW, I wanted to mention that I think your boominator is super cool. I've been working on a bicycle mounted sound system as well based on T-Amps. You can check out a few photos here <a href=http://www.flickr.com/photos/macpaulster/sets/72157612483184893/.com> How does the Boominator sound? Are you happy with the result? Anything you would do different? |
#48 |
Saturnus, where can you buy these trafos? Are there different ratings? How do you determine which ones to use for a specific application?
#49 | |
Are you sure you can use the transformer instead of cap? The transformer secondary builds a DC bridge on the secondary. Did you try it?
#50 | |
Don't just take my word for it though. In the Boominator thread there's an Aussie guy who succesfully made a clone of it, and he's equally impressed. And I'd say the sound quality is probably better than 90% of all home stereos sold today. Definately many leaps ahead of ALL other boomboxes/iPod players regardless of cost. I truly believe that apart from the improved tweeter option and the larger solar panel suggested in the thread there's absolutely no way to improve the design. I am however working on making it an easier DIY build. |
| Tripath 2020 amp: 41Hz amp6 kits (unassembled) | hifidaddy | Swap Meet | 2 | 10th March 2007 08:15 AM |
| Autocostruire Tripath 2020 Amp | mourip | Swap Meet | 2 | 1st July 2006 08:57 PM |
| FR125S + Tripath 2020 Charlize, am I crazy? | eVITAERC | Full Range | 4 | 6th October 2005 03:37 PM |
| ZEN brothers and low efficiency speakers | jh6you | Pass Labs | 6 | 24th June 2003 04:35 AM |
| Efficiency of Two Speakers in Series | markkanof | Multi-Way | 17 | 2nd May 2002 07:37 AM |
| Page generated in 0.10661 seconds (85.37% PHP - 14.63% MySQL) with 10 queries |
