Nuuk's active pre for Si T-amp...
Old 19th October 2005, 10:29 PM   #1
ThomasS is offline ThomasS  Denmark
Default Nuuk's active pre for Si T-amp...
Can the active pre run on +/- 13v? (SLA power my SI T-amp and it would be nice to do the same on the pre)
Can the gain be increased to ~6dB? (PLLXO causes some insertion loss in my bi-amp system....)
Thanks,
Thomas
Old 20th October 2005, 07:21 PM   #2
Default more info
The pre amp is described here:
http://myweb.tiscali.co.uk/nuukspot/...nclonepre.html
The voltage is specified to 15+ v - but what about 13v....
Thomas
Old 23rd October 2005, 11:02 AM   #3
Default output impedance?
What's the output impedance of this pre amp?
There is a 100k resistor between output and ground
is this correct?
Thomas
Old 26th October 2005, 11:28 AM   #4
Unhappy please comment......
I could just build it and see...... BUT I would prefere some gain....
Thomas
Old 26th October 2005, 01:07 PM   #5
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The 100k doesn't harm but would do anything either i think.
13V supply should be OK with possible a little less output level - but still enough to wildly overdrive your GC!
This is a buffer (if I got the right diagram on the site) so no gain, I'm afraid. You really need 6dB gain? How about just turning up the vol control a bit further, or rather turning it less far down?
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 26th October 2005, 01:50 PM   #6
jan.didden's Avatar
Correction: The 100k ensures the output floats to gnd if connected to a capacitor-coupled power amp input.
Old 26th October 2005, 05:17 PM   #7
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Beat me to it!
ThomasS, you may find that with the buffer in between the volume control and class-T amp that you don't actually need the extra gain!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 26th October 2005, 06:15 PM   #8
jan.didden's Avatar
Originally posted by Nuuk
Beat me to it!
[snip]
Wow! That was close , almost got caught with a mistake.
Jan Didden
Old 26th October 2005, 06:31 PM   #9
Default PLLXO...
The passive line level x-over causes quite a bit of attenuation but I'll give it a try
Old 26th October 2005, 06:50 PM   #10
Nuuk's Avatar
Then go active! It's not really difficult. If you want to keep with the Les Sage buffer concept, then try these .
Hardly any more work than the buffers and you have your crossover filters as well!
Jan - yes, lucky to corrected that one. I've seen people shot on this forum for lesser mistakes!
Nuuk's active pre for Si T-amp...Hide this!Advertise here!
Another victim of Nuuk john blackburn Chip Amps 40 16th July 2008 06:49 PM
Calling Nuuk. Colescuttle Everything Else 3 17th January 2007 07:47 PM
Pcb for Nuuk's buffer endia Chip Amps 9 23rd December 2005 09:10 AM
PCB for Nuuk's Buffer dsavitsk Chip Amps 19 21st October 2005 01:09 PM
Nuuk, What is your Favorite T-amp? HolyGhostFire20 Class D 2 23rd August 2005 12:59 PM
Copyright ©1999-2017 diyAudio
