Charlize, my thoughts Charlize, my thoughts - Page 51 - diyAudio
Old 28th September 2006, 08:56 AM   #501
Pano is offline Pano  United States
Pano's Avatar
No offence taken!
Yes, that is what is being discussed there. It's going to be tricky to do. You will be more sure of your results and the long life of the amp if you use a good input cap.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 2nd October 2006, 08:43 AM   #502
fosforo is offline fosforo  Italy
Originally posted by vt4c
Hi Nik,
You forgot one important stuff...The speaker biding post...
You can opt for a simple on/off switch for 'soft-start' as what I did for my version of Charlize....
I could not see any of these images ...
Old 2nd October 2006, 02:12 PM   #503
vt4c is offline vt4c
Charlize - Internal wiring......
Old 2nd October 2006, 02:13 PM   #504
Charlize - Front view......
Old 2nd October 2006, 02:15 PM   #505
Charlize - Back view......
Old 2nd October 2006, 02:16 PM   #506
Charlize - Side view......
Old 3rd October 2006, 01:44 AM   #507
gychang is offline gychang  United States
beautiful, like the cover off the best...
gychang
Old 3rd October 2006, 10:03 PM   #508
niknik is offline niknik  Denmark
[B]Hi Nik,
Thanks vt4c, and thanks for the pictures, it will help me to build my own.. My Charlize will arrive in two days, and I look forward to mess with it :-) It's gonna be hooked up with a modded Squeezebox and some 95dB (C17-III) speakers from Troels Gravesen, he makes some really nice designs -if anybody should be interested:
http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm
I already got a smps skynet 8080 power supply -do I need anything between the smps and the amp? (sorry this question has probably been in the thread but I am a little confused)
Old 3rd October 2006, 10:24 PM   #509
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Start with nothing, listen, and then add caps and listen again. When you get to say 4K7 or above, add bypass caps, say 100 nF polypropylene types. There really is no substitution for finding the best arrangement for your ears.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 4th October 2006, 09:25 AM   #510
I've changed my project based on Charlize due to all the tips i've found on the web.
My final setup is:
1. Charlize with air core inductors
http://www.diyparadise.com
2. SMPS Skynet 8080 as PSU
http://cgi.ebay.it/SMPS-8080-Power-S...QQcmdZViewItem
3. CAPS: 2x4.700 Uf/63 ELNA with 100pf bypass Caps and 1x6K8 5W as discharge resistor
3. Mundorf Mcap 2.2 uf as input capacitors
http://www.lautsprechershop.de/hifi/cond_mun_en.htm
4. Stepped Attenuator 10K
http://www.diyfidelity.com.au/produc...447f5df044bdd4
5. Case Galaxy from hifi2000
http://www.hifi2000.it/default.asp?id=16&mnu=16
6. A couple of gold plated RCA
7. A couple of gold plated Speakers socks
8. CAT 7 Cable for wiring signal path
9. OFC cable to wire Charlize to speakers socks
hope it helps
Any comment or opinion is well accepted
byez
Fabio
Charlize, my thoughtsHide this!Advertise here!
Charlize 2 dweekie Class D 72 25th September 2010 01:51 PM
Charlize, with or without a pre? zacster Class D 12 17th May 2007 02:08 AM
WTB: Charlize mrbigtube Swap Meet 0 25th June 2006 07:18 PM
TVC for Charlize? Gremlin Class D 0 28th May 2006 01:38 PM
WTB: Charlize JohnnyBoy Swap Meet 1 27th January 2006 03:34 PM
Copyright ©1999-2017 diyAudio
