Go Back   Home > Forums > Amplifiers > Class D
Old 30th September 2005, 04:46 PM   #1
ashok's Avatar
Default Amp2 from 41Hz with +/-60V supplies
Has anyone used the Amp-2 from 41Hz.com with +/- 60 V dc supplies. If so how did it work out ?
Additionally did anyone run the board with 4 power MOSFET's per channel ? What other parts were changed ?
There is some info on upgrading the Amp-2 module on the 41Hz.com forum , but I wanted to know details from someone who has tried it.
Thanks.
AM
Old 1st October 2005, 02:49 PM   #2
ashok's Avatar
Since no one has replied I guess it means that no one has tried any changes on the Amp-2 kit from 41hz.com .
That is really surprising.
AM
Old 1st October 2005, 02:51 PM   #3
Bgt is offline Bgt  Netherlands
waiting for Jan to finish his new Amp2 pcb design, if finished I order 1.
Kind regards,
Bert
Old 1st October 2005, 02:58 PM   #4
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I have amp2 but it is in standard config and runs on +/-47V supplies.
Old 1st October 2005, 03:06 PM   #5
ashok's Avatar
I plan to use two pairs of STW38NB20 per channel and make the modifications as Jan has suggested on the 41Hz forum.
Maybe +/- 55 volt supply . But all this only after several weeks. Real world work is pretty intense right now. Meantime I will collect all the extra parts that I need. I already have the first revision board.
Cheers.
AM
Old 10th September 2008, 09:38 PM   #6
hemos is offline hemos  Canada
I know this thread is pretty old, but you think it would be possible to run Amp2 with 3 12V SLA batteries in series ?
Old 11th September 2008, 10:57 AM   #7
It's pretty likely - you can know for sure if you find out what Tripath chip is in the Amp2 and check what the minimum rail voltage is. Depends on if it's single-rail supply friendly though. The Amp11 can run on batteries like that.
Building AMP2 from 41Hz luka Class D 20 9th July 2008 01:51 AM
FS. New 41Hz AMP2 TomWatson Swap Meet 7 14th November 2007 10:00 PM
Alternate FET's for 41Hz AMP2 gmikol Class D 2 24th November 2006 08:28 PM
Wanted: 41Hz AMP2 PCB bigmike216 Swap Meet 0 16th October 2005 10:03 PM
Page generated in 0.08382 seconds (74.38% PHP - 25.62% MySQL) with 10 queries
