UcD400 Problem
UcD400 Problem
Old 28th September 2005, 10:29 PM   #1
tomahack is offline tomahack  Canada
Default UcD400 Problem
I just finished my UcD400 amp today. Everything was fine for 15 minutes then one of the channel stop . Rails are OK at +-52 volts. Supply is Hypex HG. Any ideas?
Thanks a lot.....I'm desperate.
Do your way, it's the only way.
Old 28th September 2005, 10:35 PM   #2
Kevin Haskins is offline Kevin Haskins  United States
Turn it off and unplug it for 10 minutes or so.... and then try it again. You may have triggered the short circuit protection.
Old 28th September 2005, 10:41 PM   #3
I was casually listening to music when it stop. I checked voltage and everything seems fine. Unpluged for 15 minutes and still nothing.
Old 28th September 2005, 10:46 PM   #4
Bgt is offline Bgt  Netherlands
is the blue light on? is there running any current, I mean 6 or 54ma in 1 rail? if its 6 you're osc. is not running. Had the same a while back.
Kind regards,
Bert
Old 28th September 2005, 10:56 PM   #5
Blue light is on. 25ma on the positive rail.
Old 29th September 2005, 12:04 AM   #6
So...anything else I can try before dumping it? Any clue ?
Old 29th September 2005, 01:05 AM   #7
classd4sure is offline classd4sure  Canada
Account Disabled
UcD400 Problem Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Check the basics first like input cable connections etc. Something could have come loose.
Old 29th September 2005, 01:09 AM   #8
Already checked. Input is OK. 100kohms on balanced input.
Old 29th September 2005, 01:16 AM   #9
If that can help, I replaced the output filter cap with metallized polypropylene .68uF 250V MKP 416-420 on both module.
Old 29th September 2005, 01:17 AM   #10
Account Disabled
Sounds like your protection is tripped for some reason, pre amp possibly.
UcD400 ProblemHide this!Advertise here!
Fs: Ucd400 jev Swap Meet 0 18th May 2009 12:31 PM
problem with ucd400 slr 5000 Class D 9 31st January 2009 03:27 PM
Need help with UCD400 Buzzy Class D 2 6th August 2008 12:01 PM
UCD400 problem lucpes Class D 0 18th May 2008 07:11 PM
Copyright ©1999-2017 diyAudio
