Share my Soft Start Module for large Transformers - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 29th August 2005, 08:53 PM   #1
dddac is offline dddac  Germany
Lightbulb Share my Soft Start Module for large Transformers
Made a simple and effective Soft Start Module for my 800VA Transformers for my ZAP Pulse amplifiers.
Works great. 8 seconds for the Tx to build up the inductionfield and it stops me resetting main fuses and there is no large hummm when the amplifier starts.
All safe stuff with low 12 V DC as well
FYI
Doede
Old 29th August 2005, 08:54 PM   #2
more pics
Old 29th August 2005, 08:59 PM   #3
circuit
Old 29th August 2005, 09:00 PM   #4
pcb
Old 29th August 2005, 09:09 PM   #5
Mark Kravchenko
mwmkravchenko's Avatar
Default Slick!
Thanks!
MArk
Mark
www.kravchenko-audio.com
Old 29th August 2005, 09:22 PM   #6
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Nice, thanks for sharing that.
Old 30th August 2005, 03:01 AM   #7
maxlorenz's Avatar
Hi Doede:
I presume there will be a kit offer for the lazy
It looks smaller than ampslab's offer wich works very well.
http://www.ampslab.com/inrush_schematics.htm
Isn't 8'' too much?
Thanx
Mauricio
Old 30th August 2005, 06:22 AM   #8
Guys,
Nice circuit. However there must be more distance on the PCB between the copper tracks of the circuit what is conencted to mainsvoltage and the low voltage.
6mm is the real minimu,m better is to go for 8mm.
Below 6mm you can have a dangerous situation!!
Jan-Peter
Old 30th August 2005, 10:59 AM   #9
Kenshin is offline Kenshin  China
Kenshin's Avatar
Why do it on the mains?
It could also be done on the second stage. (Large current relay needed)
Old 30th August 2005, 06:07 PM   #10
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by Jan-Peter
Guys,
J-P, you are right in general but not in this case. As long as Doede only uses his 12 V to drive the relay he must consider insulation between 230 V parts at the pcb and 230 V towards his chassis. So 8 mm from screwholes to any traces must he consider. I don't like the 230 V connection to the transformer, too short crepage distances. I use 3-pole 5 mm grid and uses only pin 1 and pin 3. Pin 3 is unconnected.
The smoothing needs only to be 100-220 uF for driving a relay. 2200 uF makes only the transformer warm.
The 230 V traces should withstand 10 A fuse so a little bit wider would be good. 100-150 mil wide and 70-105 um thick.
My softstarter can be found here if you don't know it already. I use the "dangerous" transformerless but reliable solution.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Soft-start circuit with no relays and no aux. transformers Eva Power Supplies 102 29th March 2015 11:25 PM
Soft Start Module HaLo6 Power Supplies 21 21st March 2013 10:18 AM
HYPEX Parts F/S! HG Mono Power Supplies, Soft Start, TR501A Transformers! Socrates428 Swap Meet 0 27th April 2008 01:30 AM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Soft Start Circuit With Multiple Transformers SkinnyBoy Parts 11 10th June 2004 03:36 PM
Copyright ©1999-2017 diyAudio
