Tripath-Amp 1-B gain problem
Old 27th August 2006, 11:28 AM   #31
Bgt is offline Bgt  Netherlands
Thomas, there is nothing more difficult than comparing music from 1 person with his setup to the other with his setup. I can only compare if I have my own references otherwise "you're skating on thin ice"(Dutch sentence). You need some default amps. to compare to. Differences are not that big between amps. and to remember them is even harder. So I have a pile of class D amps. so I can get a honest picture and draw my conclusions. Also asking other people to listen to the differences helps a lot. 1 person(me f.i.) may be too focused on a mod. which he thinks is it and when another person(audio minded) listens to it he/her may find it insignificant.
Kind regards,
Bert
Old 28th August 2006, 06:42 PM   #32
drowned my coils in plastic so the windings are unmovable on the core.
Now I have to hear what difference that makes.........if any.
And after this the coil of the smps....?? Who knows??
Kind regards,
Bert
Old 28th August 2006, 08:08 PM   #33
Ok, did the transf. also.
UCD still is more balanced, more depth. UCD highs are so d.mm clean. Also UCD bass is so tight/controlled and deep.
Did it improve....don't know yet. Have to play some more.
The Amp1B sounds impressive and if I did not have the UCD to compare to you would think...wow, but when you compare it.......hmmmm.....still not there.
Kind regards,
Bert
Tripath-Amp 1-B gain problemHide this!Advertise here!
Weird Problem with Tripath amp and HTPC nanl2053 Chip Amps 6 1st February 2009 12:43 AM
Tripath TA0104 Eval Board Problem - Help! laugoo Class D 0 2nd June 2008 07:06 AM
Tripath Crackles caused by a pot problem? Rod_T Class D 4 27th October 2007 11:55 PM
Tripath AMP1-B noise disappears after 5 minutes problem Bgt Class D 9 17th September 2005 10:50 AM
P3a gain problem PetarLD Solid State 2 20th March 2004 04:10 AM
