Tripath-Amp 1-B gain problem - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 24th August 2006, 02:42 PM   #21
Bgt is offline Bgt  Netherlands
Thomas, just take the transformer out, unwind it and put 2 windings on. Thats all realy. You have to cut some pcb track underneath to make it a 2 supply line type of connection.
rt7085, the tone is unhearable in normal conditions and is not related to the psu. Tried that already.
Kind regards,
Bert
Old 24th August 2006, 04:14 PM   #22
Hi Bert,
easy for you .
We poor people full of fears need some more instructions .
Please, many people would try SMPS with class D, maybe you have invented something new that is worth to share! Could you post some more datailed instructions (type of wire, number of windings, winding technique, some picture... )
Or maybe you could sell custom transformer like yours. I would buy them immediately. I just need a couple for two bridged AMP1 or two new AMP4 just released from 41Hz.
Ciao
Thomas
Old 24th August 2006, 06:44 PM   #23
Originally posted by thomaseliot
many people would try SMPS with class D, Could you post some more datailed instructions (type of wire, number of windings, winding technique, some picture... )
the transf. can only take 150VA. They are not as nice as true smps's. They blow quite easy if you do something wrong to them.
I am getting some more of these so I'll keep you updated and post some pics. Tried the 220VA version with two UCD180's but it blew up at startup because of the 40.000uF caps.
Kind regards,
Bert
Old 24th August 2006, 08:45 PM   #24
some pics
These were the 220VA ones.
Kind regards,
Bert
Old 24th August 2006, 09:04 PM   #25
some pics.... These were the 220VA ones.
I red that these trasformers have a minimum load. If it is true why your AMP1 works? Is it stable?
150 VA are enough when using two, with two AMP1 bridged in 8 Ohm. SMPS are nice but i can't find something ready made, noiseless, suiteble for audio.
Your Conrad seem quiet.
Ciao
Thomas
Old 25th August 2006, 10:24 AM   #26
rt7085 is offline rt7085  United States
Default Noise
Bgt, you said there was also some noise that would go away after 5 min. This may also be the supply, when it is pulse-skipping under light load conditions. If the supply warms up a bit, its operating point may shift slightly and it may slowly come out of pulse skipping or simply change it characteristics. Pulse skipping, in burst mode may also cause tones, which sound like 'birdies' (fluit toontjes...). This is because it bursts at a rate which is in the audio band. I had similar issues with a switcher amplifier fed by a boost-mode SMPS.
Never give up and play fair.
Old 25th August 2006, 01:17 PM   #27
I red that these trasformers have a minimum load. If it is true why your AMP1 works? Is it stable?150 VA are enough when using two, with two AMP1 bridged in 8 Ohm. SMPS are nice but i can't find something ready made, noiseless, suiteble for audio.
It works like a charm in my amp. No problem at all. No idling problem. Stable enough. Use it every day.
RT7085: It seems though the noise is an Amp1B problem. When starting the amp. you'll see the switching freq. change to a point were it settles. I will check again.
Kind regards,
Bert
Old 26th August 2006, 10:22 AM   #28
just testing it vs the UCD 180AD and use a lot of different music (classic, synthesized, voice) to hear the differences.
Bass reproduction is excellent(UCD's have a faster attack) and the highs are very present(a bit more than the UCD). Mid section a bit layed back. The amp. sounds utterly satisfying.
The UCD is the more balanced 1.
Kind regards,
Bert
Old 26th August 2006, 01:18 PM   #29
Source and loudspeakers? Any preamp? Crossovers?
As I have a large classic music collection, quote some title you tried: we can reproduce togother the comparison.
Ciao
Thomas
Old 26th August 2006, 06:53 PM   #30
Source= PC dig.out - DAC(dig. in) - passive pre - power amp. - switch box - speakers. All DC coupled(not the amp1b's input section).
Speakers = Driade/JMLabs/Wharfdale.
Passive preamps with DACT SMD stepper or the Aussie stepper. Sold my NAD C272+C162 and rotel 980 series last year. They were no match for the UCD's.
crossovers = no.
Music = only wav files because mp3's are usually inferior quality.
You can find the titles in another thread where I compared the BP to the UCD's.
Kind regards,
Bert
Weird Problem with Tripath amp and HTPC nanl2053 Chip Amps 6 31st January 2009 11:43 PM
Tripath TA0104 Eval Board Problem - Help! laugoo Class D 0 2nd June 2008 06:06 AM
Tripath Crackles caused by a pot problem? Rod_T Class D 4 27th October 2007 10:55 PM
Tripath AMP1-B noise disappears after 5 minutes problem Bgt Class D 9 17th September 2005 09:50 AM
P3a gain problem PetarLD Solid State 2 20th March 2004 03:10 AM
Copyright 1999-2017 diyAudio
