Go Back   Home > Forums > Amplifiers > Class D
Old 26th August 2005, 09:05 AM   #1
audio1st's Avatar
Default Basic 5066 Diagram for the Novice!
I have attatched a dia' for the newies who just want to put their SI Amp (un-modded), in a new box with a better volume control and new terminals.
Hope it is of some help?
Old 26th August 2005, 12:45 PM   #2
audio1st's Avatar
This is the Dia'.
Old 26th August 2005, 12:45 PM   #3
wadric is offline wadric  United States
Cool Ummmm, here is it?
That's a good idea, but where is the attachment?
Old 27th August 2005, 04:50 PM   #4
Thumbs up Excellent!
OK. That's great and very useful for many users who just want better connectors and a pot change. Good work!
I must have been reading your post before the attachment showed up. It was late in the night here at GMT -0500.
Old 28th August 2005, 02:21 AM   #5
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
cute dia'
Old 29th August 2005, 07:14 PM   #6
speaker is offline speaker  United States
speaker's Avatar
That is most appreciated.
Thank you for making the effort!
speaker
Old 31st August 2005, 09:37 PM   #7
tetra is offline tetra  Viet Nam
nice!
Old 1st September 2005, 12:12 AM   #8
Does anyone know what are the "original caps" values on the speaker outputs? I'm building one of them AMP3 kits form 41hz.com and need to buy all the stuff now that I have a store at hand... cause I'm traveling again soon.
Thanks !
Paulo P.
Old 1st September 2005, 12:33 AM   #9
sx881663's Avatar
Thanks !
Paulo P.
Paulo,
You should have every part you need in the kit. You will need things like a power supply, case, input/output connectors, power connector, power switch and wire. You will need a power supply buffer cap of something like 22,000uf @ 16v but no output speaker terminal caps. .15uf caps are used in the Sonic Impact but it sounds better when you remove them.
Take your time and wind the inductors neatly. This is important to the sound.
Roger
Happiness is being owned by a cat
Old 13th September 2006, 01:33 PM   #10
gychang is offline gychang  United States
Default Re: Basic 5066 Diagram for the Novice!
this is exactly what I need to do on mine, you are terrific. Being a complete newbie, is there a web page (on this side of Atlantic or is it Pacific), where I can get the part?
being a newbie, when there are too many choices I am not sure which is the right part. I prefer to order here (http://www.allelectronics.com/index.html) but not sure if the RCA input, potentiometer, and speaker out plugs are available.
thanks so much.
gychang
Bridge & Parallel 4 x LM4780 - Basic wiring diagram needed GAH Chip Amps 13 12th August 2009 01:37 PM
Sonic T 5066 (Stealth Mod) MZ Class D 1 15th January 2008 05:47 PM
Donate to diyAudio for SI T amp. #5066 sklimek Swap Meet 5 12th August 2005 03:40 AM
SI 5066 Input Cap Option Panelhead Class D 10 24th June 2005 05:15 AM
Page generated in 0.13197 seconds (66.97% PHP - 33.03% MySQL) with 11 queries
