AMP1-B: why only 25 watts @8ohms? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th August 2005, 06:55 PM   #11
sx881663's Avatar
Default missing power
Letís look at this a little. If you have 28 volt rails with a non bridged amp this means you have about 26 volts peak before the outputs canít go any further. .707 X 26 = 18.38 volts RMS, 18.38/8ohms = 2.3 amps RMS, 2.3 X 18.38 = 42.27 W RMS. This is a reasonable number as the chip is rated for 100w into 4 ohms. This would be 50w into 8ohms. With a full +/- 30 volts this looks right. These power ratings are at 1% distortion. What this means is a 1% average for the whole sine wave. This in turn means the peaks are probably 10% distorted while the rest of the sine wave is clean. I am guessing here as to actual values but ball park should do. As you noted this kind of clipping is very clearly heard so you probably are stopping when the peaks are only .5 Ė 1% distorted. I would think this could easily drop the power down to the 25w range. It all is a question of when you stop turning the control up. There are way too many variables here to be worried about your results. Just turning it up a little further would be full rated power. Remember a 1db change is about as small as we can reliably hear and 3db sounds only a little bit louder but is twice the power.
Roger
Happiness is being owned by a cat
400 watts rms 8ohms audio amp design...help darkwind_j Solid State 65 12th August 2009 11:23 AM
SI beats my AMP1-B's theAnonymous1 Class D 31 1st October 2005 07:13 PM
SMPS and AMP1 theAnonymous1 Class D 24 6th August 2005 03:16 PM
power supply for amp1 regal Class D 4 22nd July 2005 09:21 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Copyright ©1999-2017 diyAudio
