How to mod my Autocontruire TA2020? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th August 2005, 08:55 PM   #1
ac2005 is offline ac2005  Hong Kong
Default How to mod my Autocontruire TA2020?
I have recently bought the Autocontruire TA2020 module and DIY a int. amp. I power it by a SLA battery. It sings! However, it seems that the mid-range is not thick enough. I wonder if I can get better sound by replacing the input caps and power caps. Anybody have experience on it?
Old 10th August 2005, 11:48 PM   #2
theAnonymous1's Avatar
Sorry I don't have a reply to your original questions, but I would love to know where you got that wonderful little enclosure.
Nice job, btw.
Old 11th August 2005, 03:46 AM   #3
Account Disabled
I would replace the power supply caps with Blackgates rated at 1000uf 16v. They are only 5 dollars a piece. You could try Sonicaps or Auricaps for the input caps. I find sonicaps better and cheaper. If you think the bass output is to your liking than use 2.2 uf otherwise use 3.3uf for the input caps. I hope this helps out.
Old 11th August 2005, 04:49 PM   #4
theAnonymous1,
I got the case from a local shop in Hong Kong for about US$25. Seems it is not available on the internet. So you might be unable to get an identical one.
HolyGhostFire20.
Is it a good idea to reduce the value of the power supply caps from 2200uf to 1000uf? It seems that most people when modding their kits replace caps of smaller values to some of larger values. So is it better to replace the power caps with something like 3300uf or 4700uf?
I am very interested in Sonicaps. Could you tell me whether I can get it on the web?
Many thanks!
Old 11th August 2005, 05:18 PM   #5
Account Disabled
The sonicaps can be purchased at http://www.soniccraft.com/parts/capacitors.htm I don't know how much shipping costs will be worldwide. You could go higher on the uf value of the blackgate caps, but I find it isn't needed. The highest I would go for the blackgates is 2200uf. I hope this helps.
Old 11th August 2005, 11:18 PM   #6
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Exactly my findings! Try an SMPS, you should be pleasently surprised!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 12th August 2005, 01:44 AM   #7
I'm happy that you posted this answer as I'll get my Autocostruire TA2020 next monday and really don't want the mid to be thin
I'll use a good SMPS. I can adjust it from 12 to 15 volt. What is the setting of your SMPS ? I wonder if setting it at 13V would be safe ? (13.5 V is supposed to be the max).
Daniel
Old 12th August 2005, 08:59 AM   #8
Nuuk's Avatar
I'm currently running the SMPS at 12.4 volts. I think that 13 would be fine but I'm not sure how much a volt matters in the context anyway! I guess it comes down to the rest of the system and how efficient the speakers are!
Old 12th August 2005, 03:23 PM   #9
I'll play safe and set it to 12.5-12.8 volts, depending on how much this change affect the sound.
Thanks !
Daniel
Old 12th August 2005, 03:41 PM   #10
plovati is offline plovati  Italy
It seems the Autocostuire.it version.
I never tried it, but I dislike the aircored inductor (the red cilinders). A try that is wort is to use ferrite core inductors (panasonic, Tayo Yuden etc) as suggest by Tripath.
Piergiorgio
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 12:39 PM
Ta2020 Bengali Class D 0 29th September 2007 06:28 AM
An almost fully modded Autocontruire TA2020 ac2005 Class D 30 5th September 2005 04:30 PM
Eb-ta2020 opentop Class D 16 30th May 2005 08:42 AM
Copyright 1999-2017 diyAudio
