SMPS and AMP1
SMPS and AMP1
Old 5th August 2005, 05:20 PM   #21
sx881663 is offline sx881663  United States
sx881663's Avatar
Default Regulator problem
The LM317 circuit as shown by Tripath and connected as per Jan at 41Hz would be your best solution. But you do need to heatsink it using the TO220 case style part. This is just too much heat for the small part. The dropping resistor shown in the 41Hz circuit wonít be necessary for the 317 part.
Roger
Happiness is being owned by a cat
Old 5th August 2005, 05:38 PM   #22
soongsc is offline soongsc  Taiwan
soongsc's Avatar
I've used LM317's in preamps before, and they never got warm. I never even added heat sinks. It also seems using the LM317 has more components. Is a sonic difference expected between the LM7805 and LM317? Also dropping 48VDC to 7.5~9V somehow that seems a lot. There is a limit the difference between input and output voltages these devices can handle, I don't recall LM317 can handle 48V to 5 V difference.
Hear the real thing!
Old 5th August 2005, 09:07 PM   #23
sx881663's Avatar
Default LM317
Yes, you are right, the 317 is maxed out at 40 volts. You would also be dissipating quite a bit more power with this much voltage across it. A substantial heat sink will be necessary. Not the same thing as when you use it in a preamp with 5-10 volts drop. A 2 watt 250 ohm resistor in series will take care of this.
I would expect better sound from the 317 as it is a better regulator.
Roger
Old 6th August 2005, 01:21 PM   #24
soongsc's Avatar
The LM317 does have somewhat lower output impedance, but this seems to mak a difference when supplying analog circuits. I'm not sure what part of the AMP2 the 5V is supposed to supply, but if it's just digital (discrete) portion, then the difference might not be that significant. I'll look into it when I get the kit.
Old 6th August 2005, 03:16 PM   #25
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I just finished the first of the three 5v supplies I need and I am very satisfied with how it turned out. Under a full load of 1.5 amps it only drops 10 millivolts.
The space between the input wires on the left and the small white cap is for a 47ohm resistor if I decide to use one. I didn't have any laying around so its jumpered with wire for now.
soongsc, the 5v is for the analog input section for both AMP1 and AMP2.
SMPS and AMP1Hide this!Advertise here!
Amp1 vs Amp3 (41Hz Audio) Mick_F Class D 11 20th October 2005 09:20 AM
SI beats my AMP1-B's theAnonymous1 Class D 31 1st October 2005 07:13 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
buying a panny instead of amp1 regal Class D 8 29th July 2005 06:56 AM
power supply for amp1 regal Class D 4 22nd July 2005 09:21 PM
Copyright ©1999-2017 diyAudio
