Inductors in T Amp
Inductors in T Amp
Old 7th July 2005, 06:04 AM   #1
@lf is offline @lf  Bosnia and Herzegovina
Default Inductors in T Amp
I want to build air core inductors for my T-Amp.
Does anybody know how many wire turns, wire diameter (in mm) and air core height and diameter (in mm)?
Old 12th July 2005, 08:36 AM   #2
dillo is offline dillo  Italy
dillo's Avatar
Take a look at this.
http://colomar.com/Shavano/inductor_info.html
It's a good starting point
bye
Old 12th July 2005, 12:17 PM   #3
Thank you! Now I have toroids And I know value - 10uH
Old 12th July 2005, 12:24 PM   #4
My T-Amp
Old 12th July 2005, 01:22 PM   #5
audiotux is offline audiotux  Germany
Hallo @IF ,
thank you for the pictures of your T-Amp .
Can we see more pictures from the PCB ?
Can you please explain the Mods you have done ?
Greetings from Germany
Jürgen
Old 12th July 2005, 06:01 PM   #6
My English is not so good but I'll try to explain...
First thing is that the shortest (possible) signal and/or power supply path is THE MOST IMPORTANT thing here. Like for the GainCard/GainClone amp. Again THE MOST IMPORTANT thing. If you fail here and leave only few millimeters of wire more than it's necessary result will be not so good.
You need good magnifying glass. I have two of them.
Big one is 7.99 eur and small one which is part (eyepiece or ocular) of toy microscope set. If you want you can find this toy microscope at
Toys "R" Us Ltd.
Concord, ON L4K 4M5
Maidenhead Berkshire UK
or
Toys "R" Us AG, 8305 Dietlikon
Koeln, Deutschland
Without this and good soldering iron you can't do much. But with this you can put two 1000-2200uf/16-25V caps close to TA2024 as TRIPATH suggest (see picture )
Old 12th July 2005, 06:40 PM   #7
Then you need SLA battery and battery charger
And keep wires between TA2024 and battery as SHORT as posible
Old 12th July 2005, 07:01 PM   #8
Next replace DIODES.
Find MBRS 130 T3 SHOTTKY 30V 1A diodes. Or other suitable Ultra Fast Recovery diodes
For maximum effectivness these diodes MUST be located close to the output pins and returned to their respective PGND tm
This means try to move new diodes closer to TA 2024 chip.
Old 12th July 2005, 07:23 PM   #9
... then you need some SODER-WICK from Chemotronic or any other company AND minimum 100 m of silver wire, if possible
and here you have link about soldering SMD components...
http://members.lycos.nl/anthonyvh/index.php?page=smd
When you finish reading this you will realize that soldering smd's can be easier than we think...
Old 12th July 2005, 07:38 PM   #10
Inductors in T AmpHide this!Advertise here!
Inductors tumler Solid State 10 10th April 2014 09:49 AM
diy inductors speedie Parts 23 21st October 2009 12:02 AM
inductors tonysherwin Multi-Way 3 7th May 2008 10:00 PM
A little help with inductors Kram Parts 2 8th February 2004 07:04 PM
Anyone tried these inductors? blank527 Pass Labs 9 9th January 2003 02:16 PM
Copyright ©1999-2017 diyAudio
