UCD400 boxed
UCD400 boxed
Old 9th July 2005, 12:14 AM   #11
ghemink is offline ghemink  Netherlands
Originally posted by Bgt
power consumption idle = 97ma
full power, 1 Kc sinewave@100V peak(just not visibly distorting) on 8 Ohms(both channels) = 1450 ma
Absolutely a more environment and wallet friendly amp. than my NAD C272.
Is that 97mA for the + rail? Is it for one module or for both together?
Best regards
Gertjan
Old 9th July 2005, 07:27 AM   #12
Bgt is offline Bgt  Netherlands
all measured at the mains input. So idle is 97ma x 230V= 22VA.
Its the total amp. comsumption.
Old 9th July 2005, 12:16 PM   #13
So 11 Watt per module. Assuming you have +-60V supplies, that would be 90mA per rail. The minus rail pulls a bit more current, so the + rail should be something like 60mA or so. Makes sense.
Best regards
Gertjan
Old 9th July 2005, 05:11 PM   #14
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Default Bgt:
Yes, very elegant solution.
<<Concerning the position of the PCB, I tried to put it vertically but then 1 side of the T bone piece got too hot. The way it is now it is more evenly hot/cool on the PCB. There are cooling vents in the top and bottom cover just where the heatsink is positioned. Just look at the pic. Here you get your convection cooling airflow.>>
But for the cooling issue I wouldn't be concerned about T bone piece asymetric warming; that's its function. For the T bone piece you have more than enough with your heatsink. I understand that convective cooling will only benefit the heatsink-Mosfets, not the secondary transistor-opamps-coils mounted on the PCB.
Am I wrong?
Best wishes
Mauricio
Old 9th July 2005, 06:39 PM   #15
In the top lid there are also venting slots and because the PCB's are mounted on a quite low position in the housing there is a lot of air around the parts and this air comes out on top. The heatsink is mounted on the low side of the cabinet so there is still some space for the hot air to go out on top.
I measured the heat everywhere and the biggest heat comes from the heatsink/Tbone, not the 12Volt transistors and output coil. Yes they feel hot but have no heatsink. These are just minor heat generators. The output Fets have a idle current of about 60ma x 120 Volts which is about 7.2Watts to burn for each amp. Maybe more. Bruno will know.
If you feel the amps. temperature after playing for 8 hours you will feel that the heatsink has the biggest chunk of heat from the output fets. The heatsink will reach 55C.
I had them vertical in my first try of the UCD's in a housing used for my Crescendo's. But this was not the best solution. The housing was bigger and had a lower volt toroid(2x35V) so it did not get that hot.
UCD400 boxedHide this!Advertise here!
Peerless 830452 New Boxed Quad 66 Pre amp ANTHONY2181 Swap Meet 6 11th March 2010 08:07 AM
OB bass equalisation for boxed sub's. ashok Subwoofers 4 24th April 2009 03:15 PM
FS Boxed plate amp, OB use 2litre Swap Meet 0 3rd January 2009 11:37 PM
UCD 180 boxed Bgt Class D 11 24th July 2005 09:45 AM
RS Labs RS-A1 Tonearm New Unused Boxed mozfet Swap Meet 4 6th September 2004 10:51 PM
