Hi-Fi Class-D Amplifier - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 5th July 2005, 03:48 PM   #1
Default Hi-Fi Class-D Amplifier
Hello guys, im a bit new to this forum!
So i am currenty developing a feedbackless Hi Fi class-D amplifier! Here is the schematic: http://ftp.torespont.hu/solarian/classd/kapcs-uj.JPG My problem is that, that the LM319 comparator picks up really lot of noise(oscillating or sy)! Ive disconnected the output of the comparator from the 4070, totally grounded the audio_in pin, and the noise is still there! The Triangle wave is almost perfect, no dc offset, but the square wave's duty cycle at the output of the lm319 is not 50%!
Here is the PCB: http://ftp.torespont.hu/solarian/classd/uj.jpg
Old 6th July 2005, 04:52 AM   #2
Workhorse's Avatar
I think you should apply the voltage divider to bias the non-inverting input of the comparator to half of the total supply and this would get you the 50+50 % duty cycle also.......
try this!
Old 6th July 2005, 09:46 AM   #3
hm..... It did not solve that problem
Old 6th July 2005, 10:14 PM   #4
Hello Solarian
Maybe it's because the LM319 has about 50 nS shorter delay for a positive transition, compared to the negative transition.
It's hard to read your switching frequency, when we don't know the value of R4 ..
www.newclassd.com
Old 7th July 2005, 01:35 AM   #5
hello!
I forgot to put that in, but the switching frequency is around 300Khz!
Old 7th July 2005, 06:58 PM   #6
Send a message via ICQ to digitoxin
The IR drivers are noisy things. You should put them at low distance to the fets with some distance to the comparator.
And use a RC-lowpass for the logic & comparator supply (or the IR supply, but don't tie them together like you do it now).
digi
Old 9th July 2005, 06:43 AM   #7
Account Disabled
Send a message via AIM to classd4sure Send a message via MSN to classd4sure
Good luck! Sounds like an ambitious project, it may not be all that high fi but it will be cool and you'll learn alot.
You haven't described this "noise" in any great detail.
What Lars Clausen describes makes alot of sense, coupled along with real world inputs and parasitics you're liable to have some DC offset as well which will contribute to an error in duty cycle, and Workhorse's idea should help with that in order to give the input a good dc operating point.
What I think you are likely to be a victim of is a slowly transitioning signal(s) on the input of a fairly fast comparator causing multiple/spurrious switching because it's having a hard time deciding which way to go while the inputs are close to one another.
You might try adding some positive feedback (hysteresis) around your 319 to help with this, it's a schmitt trigger is is somewhat useful in class d.
Looks like the perfect circuit to start with. Keep posted.
Chris
Old 9th July 2005, 09:43 AM   #8
Hello classd4sure!
Thank you all for these infos, ill try the positive feedback today! The noise is like when you tune an old radio tuner! So sometimes the noise is there (not whitenoise) and sometimes not!
Old 10th July 2005, 12:29 PM   #9
darkfenriz's Avatar
You might use an input lowpass RC filter with pole at less than 100kHz to avoid any 'parasitic' modulation in a comparator.
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 29 26th January 2014 11:25 PM
Class A Amplifier Jean-Paul_2 Solid State 22 21st June 2009 03:36 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
Copyright 1999-2017 diyAudio
