| Class D Switching Power Amplifiers and Power D/A conversion |
#11 | |||
If you can't go loud enough with the pot at full volume, then is the time to increase the gain. Quote:
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#12 |
Well lets hope some more post their results
Regarding the battery I started using a pair of 10,000uf Siemans sikoral which seemed good enough, I tried the snubber on the end of the caps but to be honest I feel it does not suit this set-up too well, the sound certainly changed but something was not right, strange because it worked great with the GC's try it Nick and let us know what you think.Reading other posts it seems the input stage is the biggest flaw with the SI T-amps, removing the inductor and replacing the low value ceramic coupling cap with around 2.2uf polypropylene is supposed to make a huge difference. Also alot seem to say an active pre improves the T-amps alot, most seem to use tube pre's BTW did the cheque arrive ok NUUK? |
#13 | ||
Posted this morning by first-class.
#14 | |
#15 | |
Pictures of my Latest T Amp
Happiness is being owned by a cat |
#16 |
Thanks Roger
I've just fitted a pair of used spare 680uf BG NX caps on the pcb for the decoupling temporary until the 330uf Rubycon ZA's arrive (they are on back order). Bloody things was a tight fit but sound a lot better than the supplied caps |
| For Sale: Tube Amps, Class-A Amps, BG Ribbons, Chassis and Other Goodies! | opc | Swap Meet | 23 | 2nd November 2009 05:04 PM |
| Big sale thread: PHL, Raven, Amps, In-wall/ceiling speakers, Amps, VideoRequest | mbcouple | Swap Meet | 2 | 27th October 2008 10:27 PM |
| SMPS for diy audio amps and multi-channel diy amps (and their power supplies) | tlparker | Solid State | 18 | 31st August 2006 10:39 AM |
| Why do some Bogan amps sound so good as guitar amps? | amperex | Instruments and Amps | 7 | 22nd June 2006 11:46 AM |
| Has anyone compared GC amps(LM3875/3886/4780) with other DIY SS amps(Leach,ESP) ? | percy | Chip Amps | 31 | 13th January 2006 01:33 AM |
