| Class D Switching Power Amplifiers and Power D/A conversion |
#21 | |
http://www.grimmaudio.com/images/admodule.jpg (It pays off tho. Full scale THD=-129dB, all freqs) |
#22 | |
Looks very nice BTW. Just out of curiosity: What is the price of such a converter ? How does it compare (sonically) to the usual 5th order converter as proposed by Sony ? Regards Charles |
#23 | |||
They're all inside the loop. The input signal is fed to the summing node through only 2 resistors. Other deltasigma ADCs have an equal number of op-amps in the loop, except that they're invisible (inside a monolithic chip). Furthermore, the switch-cap topology of monolithic ADC's requires a buffer in the input which my continuous-time circuit doesn't. In other words, I've got a much more purist design, with much less in the signal path outside the loop. Quote:
See AES ppt 5823, "Design Techniques for High-performance Discrete A/D Converters" for info on how the circuit works. |
#24 | |
This seems to be a really cool converter indeed ! I always like topologies where the active gain stages are within the forward path only.
Regards Charles |
#25 |
About the "idle tone" problem: I am currently doing an analysis of that effect. My theory is that they are caused by what is called "subharmonic oscillation", something known to exist in higly nonlinear systems. And in a sigma-delta-converter, the comparator is a highly nonlinear thing (in the small-signal point of view, it is always in saturation). The problem is that most of the methods dealing with this effect are just for analysing and not for deriving design tips. I might be totally wrong with that approach, but i give it a chance since what i experienced reminded me of typical sub/superharmonic oscillation scenario.
digi |
#26 | |
#27 | |
Is it possible/good to do it with CD4069 CMOS hex inverter instead of OPAMP?
#28 |
It should theoretically be possible to make an experimental d-s modulator with those but don't expect high-end performnance.
Regards Charles |
#29 |
I tried this some time ago, to see if it's possible to make a good simple el-cheapo Class D.
It sounds ok, and it works fine BUT it makes ugly noises at start, stop and clipping. And it has too much DC out. Can be fixed of course, but after that you will have the same price as the usual setup with opamp integrator, comparator, gate driver etc. So it's not worthwhile. No matter which modulator and driver you use, the choke, mosfet's, PCB, assembly and power lytics still cost the same...
www.newclassd.com |
#30 |
At Philips we had a chap in Vienna who did everything with 4069 chips, including, at one time, a class D amp which even went into a product. Performance was shameful, especially noise, but it worked. Many of the cheaper Philips micro systems were built using 4069 from the ground up.
| Sigma Delta Bandwidth | d1983 | Class D | 1 | 14th November 2007 03:17 AM |
| Sigma Delta ICs | d1983 | Class D | 11 | 6th November 2007 08:23 PM |
| Help in conlfict PWM Vs Sigma-Delta | danielpasti | Class D | 12 | 18th August 2006 03:39 PM |
| How does a delta sigma DAC work? | Bricolo | Digital Source | 21 | 5th June 2003 06:29 PM |
| Page generated in 0.11704 seconds (83.56% PHP - 16.44% MySQL) with 11 queries |
