Go Back   Home > Forums > Amplifiers > Class D
Old 13th June 2005, 11:42 PM   #1
Default URGENT! Dead Time Needed for Discrete Gate Driver
Hello all!
I have one week to finish my graduation project but there is a problem; shoot through
so i need a dead time circuit to overcome that effect
Please do not offer an external series gate resistor shunted by a reverse biased because of bad rise and fall times of output signal
Thanks in advance!
Old 14th June 2005, 04:41 AM   #2
MOER is offline MOER  United States
Default Dead time
We designed a class D amplifier using discrete drivers for Nakamichi.
Your triangle wave signal drive line is the only place that you can place it
basically you run a comparator with a + and - theshold and only when the threshhold is exceeded can the output fets conduct.
The circuit is on an old MSdos printout so I need a fax to send to you
Stephen Mantz
Zed Audio Corporation
www.zedaudio.com
Old 14th June 2005, 05:25 AM   #3
IVX is offline IVX  Russian Federation
IVX's Avatar
try the voltage bias for comparators to unbalance them, though res+diode not so bad idea too (just 3% more loses, or so)
Best regards,
E1.
Old 14th June 2005, 05:31 AM   #4
I once did within an old design of mine what Stepen is talking of. I once posted it on this forum. Maybe I can find it again. It was a complementary design so you'd have to watch out for the comparator input polarities.
Charles
Old 14th June 2005, 05:41 AM   #5
Here we go:
http://www.diyaudio.com/forums/showt...684#post194684
Charles
Old 14th June 2005, 05:48 AM   #6
Pierre is offline Pierre  France
Banned
Perhaps this can help: increase the rising time of the mosfets but leaving the turn off as fast as possible:
Instead of putting a resistor in series with each gate, put it connected to the NPN driver transistor. This way, when it activates, it passes current to the gate with the resistor in series (turn on), but when the PNP driver activates, it removes charge from the gate with no resistor in series.
Hope this helps.
Old 14th June 2005, 06:02 AM   #7
R Dijk is offline R Dijk  Norway
search forum i good: http://www.diyaudio.com/forums/showt...747#post429747
Here comparator drives drivers. drigvers trigger level for on/off and delayed on can bee made, it also makes it easier to make it self osscilating. In the tread the driver trigger level is also dealt with. Graduate ?
Isolated gate driver with adjustable dead band winny Power Supplies 3 14th August 2008 03:19 PM
Class-D Amp with Discrete Gate Drivers Workhorse Class D 63 17th April 2008 09:05 PM
ucd gate drive, discrete or integrated? zilog Class D 14 4th February 2006 06:23 PM
Discrete Gate Driver Help!!! defragmenter Class D 1 23rd April 2005 06:48 PM
Time Gate 24/192 digital to analogue converter Ilianh Digital Source 0 2nd April 2003 12:16 AM
Page generated in 0.08589 seconds (78.88% PHP - 21.12% MySQL) with 11 queries
