Sonic Impact PSU current
Old 2nd July 2005, 09:40 PM   #31
el`Ol is offline el`Ol  Germany
Originally posted by !
IMO, better to just get a larger supply.
My supply has 6A max. current. I`m going to test a Panasonic Class D amp, which has the Texas Instruments chips derived from the TaCT Millenium. It uses the rail voltage for volume control, i.e. it is fully-driven at any level and may not need the compression.
Old 3rd July 2005, 12:27 AM   #32
! is offline !  United States
Your results are inconsistent with anyone elses if the supply is adequate. 6A max current is sustained or instantaneous? Something seems odd about your arrangement to the extent that it is an isolated problem not seen by others.
Let me put it another way- Tripath guarantees minimal, very low distortion for at least ~4W though 4 ohm load. To get 4W output, it is manditory that the input power be higher than 100mA. With this in mind it would seem the remaining factor (unless Tripath is blatantly lying) is either your supply, the SI circuit departures from reference, or any mods you made to it (or of course the speakers).
Old 3rd July 2005, 05:35 AM   #33
I wouldn`t call it a problem. It`s just that the T-Amp reproduces timbres better than my old valve (push-pull) but has worse timing. And I will have to decide whether to use a Class D amp or build a single-ended valve amp.
Old 12th July 2005, 04:56 PM   #34
I just got an analog constant voltage power supply of the same brand and everything is running perfect. There was one piece of Bach where the T-Amp went totally out of time before, and even here - everything perfect. Probably the inernal voltage regulation of the T-Amp formed an oscillator together with the voltage regulation of my power supply, which interfered with the timing. I apologize for having made so much fuzz, but there is one thing we can learn: stay away from variable voltage supplies.
Greets and lots of fun with your T-Amps,
Oliver
Sonic Impact PSU currentHide this!Advertise here!
Sonic Impact T-amp UNPIGLET345 Chip Amps 2 10th July 2008 11:52 PM
Sonic Impact bi-amp help Commited Class D 24 27th January 2007 12:46 PM
Op-Amp Pre for Sonic Impact? Buckapound Class D 11 21st August 2006 10:42 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 11:16 AM
Sonic Impact spots25 Class D 19 6th April 2005 12:16 PM
