Sonic Impact PSU current - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 13th June 2005, 05:16 PM   #11
sx881663's Avatar
Default Sonic signature
Originally posted by el`Ol
I just listened to Stravinsky`s Sacre and I find that even heavy bassdrum attacks sound better with 100mA limit.
I am not sure what it is you are doing but it defiantly is adding some sonic signature into the amp that you apparently like. Sounds like dynamic compression would be the main component. If you really prefer this sound it begs the question, what other fault is it covering up? This is all too subjective to comment further on.
Roger
Old 13th June 2005, 05:57 PM   #12
el`Ol is offline el`Ol  Germany
Default Re: Sonic signature
Roger
Maybe it covers the fault that the sonic behaviour of the tripath chip is too different for different levels.
Old 15th June 2005, 01:19 PM   #13
I don`t have the timing problems on 8 Ohm speakers with the same efficiency.
Old 24th June 2005, 06:37 AM   #14
! is offline !  United States
Some have the SI boards without the solder-made heat slug. If you find your chip is getting too hot, that might explain degradation with higher currents.
I ended up adding the solder to mine, after which the backside of the PCB certainly does get warmer. I hesitate to recommend adding the solder because (due to the volume of solder) there is an inherant risk to it, especially if one didn't limit how long or hot the 2024 chip gets during the procedure. Also it's worth noting that due to the 'sinking grid extending past the chip itself, solder can easily pool on the top (inverted) side of the PCB before all the holes are completely saturated.
Old 24th June 2005, 08:49 AM   #15
sx881663's Avatar
I agree this is risky. I have done one successfully but in sections at different times with a temp controlled iron (Metcal soldering station). Don't think I would do another as it seems like more risk than its worth. There has been talk of sliding a thin strip of copper foil under it. Guess this would help as long as it was anchored well away from any active circuits that it could short out. Another possible solution that comes to mind would be to squirt some heat sink compound through the holes on the back side. With enough, it would have to help some. I am not sure all of the available compounds are totally nonconductive though.
Roger
Happiness is being owned by a cat
Old 25th June 2005, 07:18 AM   #16
The problem I saw with alternate heat-sinking solutions was that the SI's 2024 was just barely not touching the gridwork- perhaps it was in a few tiny elevated regions, and perhaps there is minor variation in this from one product specimen to the next.
Anyway, I'm not so sure that sliding anything under there would go very well, that if it were thick, it may not make a great contact, but if thin, it might even buckle a bit while being slid in.
Thermal epoxy might work, but since it's fairly viscous and the chip pretty close to the PCB, it could be quite tedious filling in the holes in passes as the epoxy sets, taking multiple passes to complete, plus it may not make very good contact and already being an inferior heat conductor- there's no turning back if it doesn't get the job done well enough, nor anyway to be certain the epoxy is wicking all the way towards the chip like solder should.
I did also solder it in multiple passes, allowing the chip to cool some inbetween each. I contemplated then taking a larger iron and quickly heating the whole mass for a uniform shape then decided the minimal esthetic gain wasn't worth the risk.
Old 27th June 2005, 11:51 PM   #17
I tried the T-amp with an analog lab power supply and I made the observation that it plays with a lot more drive and rhythmization when a heavy current limit is used.
Hello Oliver,
You said this and then later went on to mention specific current limits. I would very much like to understand what is going on here. Are you saying that it sounds better if you limit the amount of current that the power supply can deliver? Do you use a current limiter to do this?
Thanks,
Dave
Old 28th June 2005, 02:58 AM   #18
I use the current limit knob on my power supply. When you concentrate you realize that there is also a slight improvement on 8Ohm speakers with the poti at twelve o`clock.
I found out that the sensitivity declaration of the 8-Ohmers I used for testing wasn`t correct. Maybe for high sensitivity 8Ohm speakers the current limit is essential as well.
Old 28th June 2005, 03:27 AM   #19
Okay, good. Technically, what does the current limit knob do? Is it a potentiometer in the power line? does it control the DC voltage as well as the current?
Dave
Old 29th June 2005, 03:41 AM   #20
This is how voltage stabilization plus current limit typically works.
Sonic Impact T-amp UNPIGLET345 Chip Amps 2 10th July 2008 10:52 PM
Sonic Impact bi-amp help Commited Class D 24 27th January 2007 11:46 AM
Op-Amp Pre for Sonic Impact? Buckapound Class D 11 21st August 2006 09:42 PM
bi-amping with sonic impact t amp/using sonic impact amp for headphones jon_m Class D 3 16th February 2006 10:16 AM
Sonic Impact spots25 Class D 19 6th April 2005 11:16 AM
Copyright 1999-2017 diyAudio
