| Class D Switching Power Amplifiers and Power D/A conversion |
Hi guys
Just completed my T-amp upgrade. Am currently using it to drive my DIY horn with the Fostex FE108 sigma drivers - awesome! Pics here: http://www.auricles.com/new_page_22.htm |
#2 |
That's a beauty, great chassis and very clean layout.
Henry |
#3 |
My T-amp.......the green band glows in the dark ! light from an internal led swapped from the red to an ultra bright green.
#4 |
Neat job zanash.
#5 |
Thanks.....its a maplin box with plastic ends...easy to work I wired it up using 1mm silver [4n] wire in ptfe sleeve. All the hardware is maplin's as well. I've built two of these now and both run in biamped configuration so that one amp drives one speaker, one chanel the tweeters and the other the bass driver. Speakers are Martin Logan Aerius i's It goes as load as I need but tends to run out of steam at higher levels. But generally sounds fantastic.....replaced a Quad 707! The only thing missing is the slam provided by the bigger amp.....so I may look at a pair of eval boards at 100watts each.
#6 |
was the silver wire from maplins as well?
#7 |
no...do you need some?
#8 |
yeah
#9 |
give me an email on peter.kendall4@ntlworld.com
#10 | |
| Can this be Upgraded? | normalicy | Car Audio | 13 | 24th January 2008 06:17 PM |
| Can this be Upgraded? | normalicy | Car Audio | 0 | 23rd January 2008 06:20 AM |
| WTB- PAS-3 Upgraded or Mod PC-5 and PC-6 | Pyre | Swap Meet | 0 | 6th July 2006 06:20 PM |
| $30 amp upgraded | amt | Class D | 323 | 21st April 2006 08:48 PM |
| Page generated in 0.08296 seconds (86.07% PHP - 13.93% MySQL) with 11 queries |
