| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
Should be very interesting to see how the Amp3 compares to my diy J-fet buffered,zero feedback regulated Gain Clone.
I've also got a highly modded tube amp and an AvondaleNCC200 although the GC will probably be the main thing I'll compare it against |
#12 |
You will need a power cord and/or inlet to the chassis. Fuse holder. Transformer of 300VA with 22 VAC center tapped. Rectifier bridge. Smoothing power supply capacitors of about 10,000 uF @ 50 volts.
You will also need a 5 volt regulator and the associated parts to make one up. The 22 VAC transformer @ 300VA seems to be a bit of a rare bird. I have only found one, which is made by Plitron. Cost including shipping to CO is about $100.00 |
#13 | |
George |
#14 |
Thanks for the information.
I have sent him a e-mail. Hopefully it will be less expensive than Plitron, but just as good. |
| 41Hz AMP3 linear PSU questions | phn | Class D | 4 | 8th August 2006 03:43 PM |
| Art Taylor 41Hz Amp3 | RogerWilco | Class D | 10 | 4th May 2006 08:05 PM |
| FS:(2) 41hz Amp3 | sfogg | Swap Meet | 2 | 24th January 2006 04:52 PM |
| Amp1 vs Amp3 (41Hz Audio) | Mick_F | Class D | 11 | 20th October 2005 09:20 AM |
| 41Hz AMP3 | Pano | Class D | 12 | 25th April 2005 09:07 PM |
