| Class D Switching Power Amplifiers and Power D/A conversion |
I'm posting this here since there doesn't seem to be a forum that better matches my topic.
I see that some people on the forum (percy, Bruno and dutch among others) are discussing the difference between Class-D and Digital amplifiers. TI calls their products in the latter category True Digital Audio Amplifiers (TDAA). I believe this term is a much better way to refer to the devices in question. TDAA's typically accepts PCM/I2S digital audio streams as inputs, convert these to PWM signals to drive their (Class-D style) digital/switching power stages and then filters the signal to produce the amplified signal which goes to the speakers. I am a firm believer that TDAA's (not necessarily TI's) are the way forward and I would like to build some of these myself in the near future. Has anyone here already done so? Does anyone know how some of these TDAA's compare to each other and/or to other (ie Class-D) amps? Any other views/thoughts welcome! |
#2 | |
I'd consider the TI chip sets the best open-loop digital offering on the market if you stay with one supplier. The TI modulators are quite good and the power chips are OK. Other options are combining TI modulators with power chips by Philips and ST. I would suggest reading the other threads, because the fact that a certain chipset is the best in the open-loop digital field does not imply I think it's good. I'm not going to argue that case here because I don't think it was your question. |
#3 |
Hmm... I have some of the TI chipsets lying around which I suppose I could use to build a prototype amp for evaluation purposes. I could then combine that with my existing TI digital crossover (if I'm happy with the results of said crossover) and work my way towards a full-on digital system from there (again if all results are satisfactory). Perhaps I'll even do wireless, anyone have any experience with Bluetooth etc?
Let me munch these thoughts over for a day or so. If I decide to do this, I might even put up a website for it. |
#4 |
Theodoric: Ja well, no fine. There is already a thread on the forum called something like 'Anyone interested in building a digital amplifier...' under Class D. It's very worthwhile reading it all.
Bruno and John Westlake have been building TDAAs for many years and John Westlake's latest design - which uses closed loop feedback around the power stage - has the best measured performance of any TDAA anywhere, at any price. I've been designing and building open TDAAs since about 1995 and am presently working on yet another one. It's a serious addction and challenge to a variety of one's theoretical and technical skills. If I were you I would start off by building a stereo TDAA based on the TI modulator chip (which is probably the best available today), coupled to a discrete output stage (OPS) of your own design. Some of John Westlake's discrete OPS schematics have been posted on the forum and my own PowerDAC 2 OPS schematic - based on a HIP4081A bridge driver - is also out there somewhere. These can serve as a good base and the design and layout of an OPS with low THD will keep you out of mischief for long enough for you to forget all this BlueGum. . .Bluee teeth...Buck teeth - whatever - computerry stuff! I've attached a pic of PowerDAC 2 to whet your interest. Veels geluk John Hope
At Spes Infracta __________________ |
#5 | |
#6 |
Bruno: Yes, open loop (like TacT Millenium and my PowerDAC 2 and the TI OPS ) is what I'm suggesting Theodoric build. As you say, once one starts putting blatant analog stuff in . . .
But hey, let's not embroil this innocent newcomer in the Digital Amplifier nomenclature wars! Cheers John
#7 | |
#8 |
John Hope is the powerdac avaiable as a product or plans anywhere? I have tried searching but ended up with confusing results !
I understand its your own design, but have you made any thing available? I assume its not relkated to the Wadia product? or is it? Apologies if these are silly questions with obvious answers ! |
#9 |
I assume it is his own DIY product, although looking veeeeeeery commercial (i.e. clean and professional).
Regards Charles |
#10 |
Sorry John, I'm a computery type of guy. Like I said, I plan to first get the actual system up and running (piece by piece that is) and then much later on hopefully make it wireless.
I also find your PowerDAC quite interesting looking and wouldn't mind some more info to chew over. |
| powerful Chip - audio digital amplifier | olzon | Chip Amps | 1 | 14th November 2008 08:25 PM |
| New TI digital input audio amplifier | jkeny | Class D | 8 | 10th October 2006 03:58 AM |
| True Digital Audio Amplifier (TDAA) | DJ | Digital Source | 5 | 4th April 2004 11:13 PM |
| 32-bit digital audio amplifier ZXCW8100 Zetex | peranders | Digital Source | 2 | 20th October 2003 12:08 AM |
| Page generated in 0.12355 seconds (73.56% PHP - 26.44% MySQL) with 11 queries |
