Power stage topology - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th May 2005, 12:36 PM   #11
jan.didden's Avatar
Maybe not 100% OT, but this article gives an interesting overview of the issues, including power supplies for class-D:
http://www.edn.com/contents/images/526331.pdf
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 4th May 2005, 12:53 PM   #12
to me this smells like a Zetex advertisement !!!
Charles
Old 4th May 2005, 01:31 PM   #13
Jan Didden
This article shows how much digitally controlled class D amps are all about creating real analogue problems (power supply sensitivity, jitter sensitivity etc) only to solve an imaginary problem (the DAC and analogue signal processing).
A simple but well designed analogue class D delivers performance (measured and sonic) that makes this article's subject a joke, contains no fancy noise shapers or filters and does not need anything special by the way of power supply and is cheap to build.
I do use noise shapers and digital filters extensively, but only in DAC's. It's always better to do the D/A conversion in the small signal domain instead of trying to pull it off using power FETs.
Old 5th May 2005, 06:42 AM   #14
There is one thing that I find very interesting, almost every design that I have seen for a class D has very low distrotion up to about 100W then the destortion sky rocks. I would have thought a well designed amplifier would stay much more consistant.
Old 5th May 2005, 04:48 PM   #15
Default Distortion
This may be true in true digital non-feedback designs. In the analog PWM world, ICE Power and Hypex for example, distortion characteristics are more like Class AB amps, where they do not skyrocket until the amplifier goes into clipping.
Dan Fraser
3 stage LIN topology - NFB tappings? AndrewT Solid State 66 3rd January 2013 09:49 AM
Tetrahedron output stage topology. Circlotron Solid State 25 3rd February 2005 10:19 AM
power amp driver block topology? mlloyd1 Solid State 115 31st July 2004 06:15 AM
Copyright 1999-2017 diyAudio
